Question about Uniden GPS
Have a Uniden IGO Cam 850 / having trouble using it & manual is no help / just don't know how to operate it properly????? Keeps turning off for no reason?????
Fully charged / screen holder mounted / connected to lighter socket / set up as per manual instructions / I press the on button / LH top of unit / starts up & in no time - just turns off fully - still connected / press the on button again / goes for a short time then off again.... Why ???????
SOURCE: Digital Cam
I was encountering the same problem and solved it simply. Using a clean pencil eraser, I gently cleaned the contacts on the battery and the camera where they connect. The camera communicates with the battery, and if it cannot talk to it, it shuts down.
Be sure that you keep them clean, and if you wish to keep this from happening, put a small (very small) amount of petroleum jelly on the contacts, to keep the air from corroding them.
Posted on Jan 17, 2008
SOURCE: GN Netcom GN 6210 - headset, no worky
Not sure what you mean by won't turn on.
If you mean no dial tone when you take it out of the cradle, I have run into this. The solution is to unplug the power cord and then plug it back in which resets the unit.
Posted on Dec 28, 2008
  • 10865 Answers
SOURCE: Garmin won't fully turn on
there is a reset button under the thin frame around your screen. remove the frame by prying it up with your fingernail, push the reset button and your problem will be fixed
Posted on Mar 22, 2009
elix0411
  • 3530 Answers
SOURCE: upro go won't turn on I press on the start
Welcome to Fixya
Sounds like the LCD screen has gone bad. Try to drain the power of the board first. Take out the battery then press and hold the ON button for 10 secs. This will drain the electrostatic charge of the board the usually causes the no display problem. Put the battery back after 10 secs then power ON the unit. If same thing happens then you need to have the LCD replaced by the manufacturer if the unit is still under warranty.
Thank you for using Fixya!
Posted on Apr 27, 2011
leecom72
  • 4806 Answers
SOURCE: My laptop wont turn on and yet its fully charge.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Posted on Jun 08, 2011
How do I get the dual camera to work as only one is recording (uniden igo cam 820)
As this is an accessory for a motor vehicle, may I suggest you repost this query in a more appropriate forum.
Aug 23, 2017 | iGo Cameras
I got one of your uniden igo cam 850 recorder i dont have the wire for the camer at the back to the revising lite
sadly this is not the UNIDEN website. we do not have any of their parts hereon FIXYA
Jul 06, 2017 | Uniden Lands Phones
What of the model of my uniden camera
What is the problem, Don;t operate at night or without light, test make simulator with one lamp directly and other in a box close.
And review the specifications and modes to use this cam
May 31, 2013 | Uniden Wireless Outdoor Camera With Night...
I have a Uniden BC560XLT police scanner. I don't know how to use it.
Why not go to the Uniden website for information. You may be able to download a copy of the manual for your scanner or get some basic information regarding programming
Apr 05, 2013 | Radio Communications
UNIDEN DECT 6.0 don't have manual need to
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Sep 01, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have lost my manual and I don't know how to retrieve my messages from another phone when I'm away from home.
Which model of Uniden phone do you have? Do you remember the PIN that you have programmed into the phone? (If the PIN is not set, you can't access the answering system remotely. The Uniden phones that I know don't have a default PIN.)
For the DCT648, to access the messages remotely, dial your phone number and wait for the system to answer. Press 0 followed by your 2 digit PIN (within 2 seconds of pressing zero) while the greeting is playing. To play back all of the messages, press 0 2. If the unit is off, then you need to press 0 followed by your PIN (within 2 seconds) after 10 rings and the beep. Press 0 6 to turn on the unit.
Other Uniden phones use a 4 digit PIN. On the DECT1080, when the greeting plays, press * followed by the PIN. Then press 01 to play back the messages.
Uniden phone manuals are available at the product page (start at http://www.uniden.com and search for your phone) or from the Support page ( http://www.uniden.com/scat/cordlessphones_mnl ) . On the support page, you will need to use the drop down menu to change the type of phone (if you have a DECT phone) and then search through the pages. The manuals are listed in numerical and alphabetical order. One manual will cover several phones if the phone supports multiple handsets. So ignore the number after the dash if you can't find your exact manual.
If you add a comment with your phone's model number, I'll be glad to check the specifics for accessing the answering system for you.
I hope this helps.
Aug 16, 2011 | Uniden Cordless Phone
I bought a cordless uniden phone DCX 640 on craigslist. it came with an extra handset. My problem is that there is no owner's manual so I don't know how to use the many buttons on the phone base. ...
Your phone's owner manual can be downloaded from this location.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you out any further.
Regards, Carlos
Jun 20, 2011 | Uniden Cordless Phone exai398i
Need map of England for my Uniden 3.5 gps
no one can help you until we know what maps it uses. Many unidens were sent out with different brand maps
Igo Igo8 Navig8tor Polstar Insync Destinator etc etc.
No maps are free You need to contact Uniden because just buying a map will not work It has to be written for the Uniden engine.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Uniden MapTrax GPS352 GPS Receiver
My laptop keeps saying no bootable divice found
Hello!
I don´t know is your laptop older or is newest, but or you have trouble with you hard drive (see in bios,does you hard drive there), or you have trouble with system.
You can try repair installation (don´t lose your data), or you can install a new system.
Good luck, i hope so that I was helpful.
Nov 02, 2009 | Computers & Internet
GPS Logo
35 people viewed this question
Top Uniden GPS Experts
Shehu Pro
Shehu Pro
Martin Murray
Owen Barnes
Are you an Uniden GPS Expert? Answer questions, earn points and help others
