Question about Whirlpool Ovens
Whirlpool AKG 668/WH double oven & grill. I have lost control knob for top oven/grill (third knob from right). Can anyone please supply me with this?
    Top Expert:
  • Whirlpool Master
  • 46,177 Answers
Check with a local appliance store.or repair shop
Posted on Dec 05, 2016
Use grill on whirlpool double oven
Depends what model but on mine you have to Turn right hand knob round to grill and then turn middle one round to desired temp, I use max 11.
hope that helps
Mar 02, 2015 | Whirlpool Ovens
The temperature markings on the top oven/grill have worn off - can anyone help
the first knob has tree positions in the middle is off to the left the top (grill) heats to the right top (grill) and bottom heat, the second knob indicates the temperature in the following way ..50....100....150....200....250..good luck
Nov 27, 2012 | New World E70DOa Electric Double Oven
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Sep 03, 2009 | Ovens
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Open Questions:
Ovens Logo
32 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
