Question about RC Toys
Red cat twister xtg. Rc car wont char9 - RC Toys
Hot wheels rc terrain twister. why did it just stop working,after less than 3 hours total run time.? within 2 weeks of purchase.
probable defective Rc, return for exchange at place of purchase.
press the helpful button.
Jan 08, 2016 | Cars & Trucks
How do I change the format of my downloaded pix from NEF to JPEG?
I use GIMP 2, a free open source editor that is very sophisticated.
I think I had to install an add-on so that it would read NEF files. Gimp converts all files that are edited in it to its own "xtg" file extensions. After I finish editing, I save the picture in the "xtg" file extension then I import it in "jpg" format to the same folder where the original NEF along with the XTG formats are stored. During the editing process, I usually scale the image if I plan to send it somewhere on the web.
I think a lot of other editors have a similar function, especially if the proper codecs are installed.
In addition, in the past I have used conversion programs to do the same thing but it's been a long time. Do a web search for NEF converters and you may come up with a free program or two that will allow you to make the conversion without editing the picture.
Jan 29, 2014 | Nikon D Cameras
Hi, I just bought a Honeywell RTH8580WF1007 and tried to install it, I placed the wires in on the same letters as they were with my old thermostat. However, now that the new thermostat is wired up, it wont...
739dfb58-7a38-4a51-a7ed-ab942a7253a0.pngRH is red heat and RC is red cool, red being the "hot leg" of the 24 volt control voltage, normally you will have a jumper from RH to RC, the fact there is an RC tells me there must be an RH too?
I will look after this post and come back if any new info was found, other wise I will say call 1800 Honeywell and provide you a diagram to check out.
Aug 25, 2013 | Honeywell RTH8580WF1007 7Day Touch...
My grandson's Mattel Terrain Twister has gear problems
Return it to the store if you can. They are junk! I bought two for my boys. They stopped working properly after twenty minutes of use on Christmas morning.
Jan 02, 2013 | Mattel Hot Wheels RC TERRAIN TWISTER RC...
How do I remove a tick from my cat?
The best way to get the tick off the pet's body is by using a device such as the Tick Twister which designed for this purpose. You can find more information about the wick twister here http://www.petalia.com.au/Templates/ProdSubList.cfm?Group_No=7018
Aug 14, 2012 | Pets - Others
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Toys Logo
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
