When I have the grater, shredder, etc attachment on the xb9003 I can't close the lid and I can't figure out why. Any ideas?
Looking for coarse grater attachment for above please
Micro wave ovens do not have attachments like graters .
Apr 06, 2016 | Microwave Ovens
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
Detailed manuel for model FP2500 10 -CUP FOOD PROCESSOR
I am having the same problem. I can't seem to figure out how to insert the shredder/grater. I want my zucchini bread now!
Aug 30, 2014 | Food Processors
What is a grater?
"A grater (also known as a shredder) is a kitchen utensil used to grate foods into fine pieces. It was invented by Francois Boullier in the 1540s." (Wikipedia)
Oct 08, 2013 | Home
Shredder will not run
Sometimes paper gets stuck in the blades.Take the lid off and looks closely. Get a pen or something to dig that stuck paper out.
Dec 20, 2012 | Office Equipment & Supplies
My shredder will not turn on. Is there a reset switch?
There are a couple of reason why A shredder will not turn on.
There is a safety switch that makes sure the shredder is attached to the base. Make sure this makes contact and nothing is keeping the switch from closing.
There is an overheat cutout switch attached to the motor. This should automatically reset after the motor cools off after overheating.
If not then the last thing to check is the fuse.
Jun 21, 2009 | Fellowes DM15C Shredder
Lid broke
Yes, I have the same problem. I called GE/Walmart division, and the model is discontinued. They are sold out of the lids and bowls. So, I guess we need new food processors!!
Nov 13, 2008 | GE 106622F Food Processor
HP Pavilion ze2000 Monitor is dim
Yes, this is what happens when the backlight goes out.
This will give you an idea of what is involved in replacing the backlight. You can find a replacement backlight here, or on ebay, just take your current backlight(s) out, measure it or them, and buy replacements of the same measurements. It doesn't have to be for the same model laptop as long as the CCFLs (cold cathode florescent lamp) are the same size.
Aug 11, 2008 | Computers & Internet
My hoover steam vac
OKay! I've figured it out! After making sure I had the cleaning solution container connected properly, the "lint filter" thingy clear, the attachment plug thingy unplugged, the filter in it's proper position, (about a cm down from the seal), and the seal on the filter was all good, etc etc etc, the brushes in properly...I was about to drive over this steam cleaner with my car!
After taking a break and going back to it, I discovered that I didn't have the lid to my dirty water tank (or air tank, as I was starting to call it) properly closed. There are two lips that you have to make sure the lid "hinges" from, and THEN snap the lid shut. This made a seal that allowed this steam cleaner to **** up all kinds of gooey gunk from my carpets! The brushes work, the suction works, it's a FABULOUS machine! It doesn't get any louder when it's sucking up water, either.
All this AND I had the instructions! Go figure!
Jul 12, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
96 people viewed this question
jasbo
jasbo
