Question about Tablets & eReaders
How to delete this [virus] Trojan cause it's not letting me get to my setting it's telling me please do not reboot or turn off cause it's updating
It's keep on locking me out of my tablet and when I try deleting the app it won't let me it's telling me it's telling me that it's administrator
    Top Expert:
  • Tablets & eR... Master
  • 46,750 Answers
Take it to a computer repair shop and see if they can get around the virus
Posted on Dec 05, 2016
How can I delete my passcode altogether?
Go to Settings - Passcode and put it your passcode. An option then appears on the top of your screen to turn the passcode off.
Oct 18, 2015 | Apple Tablets & eReaders
Why do my Google play services are not available on my tablet?
1. Remove the updates for your Google Play
- Go to the menu->settings->apps->all->google play store-> uninstall updates, then reboot your device.
2. Remove the cache for your Google Play
- Go to the menu->settings->apps->all->google play store-> remove cache, then try to run your google play again. It is better to do a reboot.
3. Try to delete and re-install Google Play
- In some cases, delete and re-install resolve this issue.
4. Try to delete your google account and add your google account again
- Go to the menu -> settings -> account remove your current google account then add it again here.
Mar 02, 2015 | Tablets & eReaders
How do i delete cookies from my IRULU 7in.tablet
That would be done in the browser, in the settings. While you are there, you can also delete the cache files - also in the settings... a good thing to do once in a while.
Jan 26, 2015 | Tablets & eReaders
I have a 9in tagital tablet it says I have a trojan malware in my Google calendar plugin I cant forcestop it or disable it it wont let what do I need to do
Have u installed any security tool on it or do u know what kind of trojan it is? What did you try to do to remove it?
Maybe you can refer to my post and see if it can help
Removal Guides for Trojan Ransomlock
There are both manual removal guide and automatic removal guide to remove the trojan.
Jan 23, 2015 | Tagital Tablets & eReaders
HOW DO WE RESET TABLET. SET PASSWORD AND NOW IT WON'T WORK. TO RESET TO FACTORY DEFAULT
reset
volume up and hit power button hold for 5 to 10 seconds then the screen should turn off
now you have a very simple menu on the top sections
of five lines or so
reboot now
apply update ex
apply update from cache
you have to use the olume button to scroll with to get to the line you need
wipe delete factory reset then hit the power button to start
choose the last wipe answer the questions to get to the wipe delete
delete all used data scroll to yes
it says to reboot so
then reboot by hitting power button it will restart with new factory settings
these are known issues with getting hot make sure you purchase a power cord as they tend to go bad just saying .. i hope this helps..
Dec 26, 2014 | Nextbook Tablets & eReaders
How do i get rid of a virus that is blocking my screen and prohibitin me from doing anything
Do you have any antivirus ? If you have it, then scan your PC for malware and rootkit
Oct 20, 2014 | Samsung Galaxy Tab 4G 10-in 32GB White...
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
Kocaso M9100 user manual
Trojan virus.try to run anti virus cleaner.Or reset it to factory setting .but you will loose all saved data.
Jan 06, 2014 | Tablets & eReaders
Dell c510
First I would attempt to kill all the viruses with a very good tool called Malware bytes. It kills all of the above. Update the definitions file before you use it. Reboot after scan and run again to ensure cleanliness.
If you still want to wipe it out, you can obtain a microsoft reinstallation disk from Toshiba by providing your product key to them.
Oct 20, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Viruses invasion
hi
first scna your system with antivirus quick heal ,avast , and symantec with update definition..
then del all virus .
if u stll get problem then delete all psrtition and format install new window
Feb 27, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
