When moving i lost the lid to our washing machine model 36s605, how much does it cost to replace?
    Top Expert:
  • Washing Mach... Master
  • 51,307 Answers
Not a parts shop
contact the service agent spares and ask them
Posted on Dec 05, 2016
Cost of repairing a lid switch
You will have to replace the lid or out of balance switch.
Apr 30, 2014 | Washing Machines
I have an LG WF-T7050TP top loader (automatic) While moving houses I lost the lid that covers the top which now result to machine not wanting to wash. How can I go about replacing the lid & what is the...
Sorry but this forum does not supply parts, part numbers, costs or other details direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 03, 2011 | LG Washing Machines
'LD' on display and lid closing won't get the washer started
Hi just read your posting.Now I know you supplied the model number in your posting but could you please supply the name of the machine which should be written on the control panel.Is it an ENDURO or an ESPRIT --etc--?Please reply with additional information and I can help you rectify this problem.Looking forward to your reply.
Jul 27, 2010 | Fisher Paykel Eco IWL16
Kitchenaid washing machine model: KAWS50JQ4 Basket does not agitate. How do I determine what parts to replace
Does the washer make a noise when it SHOULD be agitating or is it completely silent? If it's completely silent then you should check the lid switch. When closing the lid, when the lid is less than 4 inches from being completely shut, you should head and/or feel a "click" when lowering the lid. If you don't hear or feel a click, your lid switch is broken. If the washer makes a noise when it should be agitating but isn't, then it's likely that your motor coupler is broken. This is part number 285753A and goes between the motor and the transmission. Should cost around $20. If the coupler is out, the machine will not spin either, leaving clothes drained, but still very soggy. If the bottom part of the agitator moves well but the top does not, i.e. "lazy agitator" then you need a part called dogs, part number 80040, in the top of the agitator. Should cost around $3-$5
May 24, 2010 | KitchenAid Washing Machines
I have a Fisher and Paykel washing machine (excellence8 7.5) and i lost the lid of the machine while moving it. I was wanting to know where to find a spare lid and how to get it working without one in the...
to get machine to work without lid you need a magnet(med size) place it on the plactic hob righthand side towards front of machine ( where the lid closes against the machine) and it will operate untill you find a lid ...:)
Mar 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Waher won't spin
Either a bad lid switch or a bad direct drive coupling or a bad timer.
Fill the machine with water. In the wash mode observe the agitator. Is it moving back and forth? If no, replace the direct drive coupling.
If yes, it does move back and forth, with the lid closed, advance the timer to the spin cycle. If it does not spin, raise the lid then close the lid. Does it spin? If yes, replace the timer.If no, replace the lid switch..
Apr 08, 2009 | Kenmore Washing Machines
Water keeps running through washing machine(simpson 36s605). have checked pump not blocked
At what height is your exit hose. It should be approximately 3 feet up from the ground and then into the drain. This is rule one for all washers, it cannot be at floor level - your water will just flow out.
Sep 15, 2008 | Fisher Paykel Eco IWL16
Kenmore 70 series
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working.
On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $25 and is fairly simple to replace if you follow the steps below:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
You can find a replacement at searspartsdirect.com. If you need further assistance, please post back and let me know.
May 10, 2008 | Washing Machines
Top Load Washer
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace. Post back with your model number and I can assist you further.
Apr 16, 2008 | Washing Machines
GE Washing Machine
Saragary,
It sounds to me like the safety switch for the washer lid is faulty or just out of adjustment (you'll find an arm sticking out of the lid that corresponds to a similarly shaped but larger hole in the jam of the lid and that is where the switch actuator should reside).
Or, your timer might be at fault, since it completes cycles once you manually advance to the next one.
Eliminate the safety switch as the possible fault before moving on to the timer itself, as the timer is more costly.
Good luck.
Mar 16, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
