Question about Winchester Optics
PRODUCTION DATE OF WINCHESTER RIFLE SN 4706033X?
SOURCE: winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Posted on May 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I just bought a winchester 308 model 100 rifle,
hELLO THERE
Please go to www.winchester.com and you will be able to enter your model number and there will be a viewable manual for this and there is also telephone numbers for tech support ok>
Posted on Aug 05, 2009
agent91
  • 2100 Answers
SOURCE: oLD PUMP WINCHESTER RIFLE
Model 61, 62a, the 61 is hammerless and the 62a has a hammer, the safety on the 62 is the hammer, the safety on the 61 is a cross bolt, sounds like it is gummed up, or busted, I would take out the trigger houseing and clean it up and check it out. If the cross bolt is stuck, something is blocking it, like the hammer at half c0ck, try pushing the trigger forward and see if it moves, whatever happens, I would still take it apart and clean it, don't screw it up, it is a very collectable rifle.
Posted on Oct 23, 2010
  • 1267 Answers
SOURCE: Hi i was wondering if
take a look at http://www.gunsinternational.com/Winchester-Model-1886-Rifles.cfm?cat_id=501&start_row=51
and other sites and you can just about make your own estimate
Posted on Jan 03, 2011
  • 4 Answers
SOURCE: Where can I get manual for winchester .17 hrm model 1885 low wall rifle
Are you looking for an operators manual? If so you can write to Winchester and they will send you one. If you are looking for gunsmithing manual, you can check with your local gun shop and they can help you out.
Posted on Oct 31, 2012
Hello anybody know
Yes, I do but please don't post disjointed posts like this one. You can bring your original post up be clicking Want Answer. If you rally want to repost, elaborate on what you said before.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... date of manufacture and value: Click here to go to our gun values resource links.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
determining date of manufacture and value: Click here to go to our gun values ..... *TOO POST-64 MODEL 94 BEGAN WITH SERIAL NUMBER 2,700,000.
Winchester Model 94 Serial Numbers - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, winchester model 94 values, Winchester 1894, winchester model 94 prices, model 94 rifle, winchester lever action, 30-30 lever action.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden Memorial ... and find dates and serial numbers on The Winchester Model 94 30 30 ? ... I am thinking of trading the rifle for a 270 or 308 but want to verify its value. Winchester 94 w/no serial 18 posts 2 Oct 2007 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Blue Book of Gun Values - WINCHESTER FACTORY WINCHESTER ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
Add $50-$75 over individual prices for consecutively serial numbered rifle and ..... Model 94 rifle in .30-30 Win. cal. with octagon barrel, extensive C. Giovanelli scroll ... Other special issue receivers were used that bear this serial number as the ...
What Is The Year And Value Of My Winchester Model 94 Serial Number ...
www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester-model-94-s...
  1. Cached
  2. Similar
May 7, 2010 - I have a winchester model 94 30/30 lever action rifle . The serial number is 1208774. It is in mint condition. I was wondering what this gun is worth. Reply. avatar. Winchester Model 94 Pre 1964 Serial Number 1105022 4 Nov 2012 Where Is The Serial Number Located 31 May 2010 Winchester Model 94 8 May 2010 Winchester Model 94 30 Wcf Pre-64 6 May 2010 More results from www.gunvaluesboard.com
Value Of A Model 94 Winchester Rifle 30-30 Serial Number Is ... ' Gun ...
www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30-serial-numbe...
  1. Cached
  2. Similar
hey wiz sorry to interrupt and i know it is rude but i have a very poor money situation and need to sell this similar winchester model 94 30-30 the serial # is ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Jan 08, 2017 | Cell Phones
It has this number 22s10r1r on it can you tell me what my 22 pump winchester rifle model 61is worth i think it was made in 1945
Here you go Gayla. Remember though, condition is everything. If you want to check the date, google;
Winchester model 61 serials
winchester rifle model 61is Google Search
Dec 28, 2016 | Winchester Optics
Winchester model 74 serial # 11901, what year was that gun made
My Internet at work doesn't like 'weapons'. These links will help you find the date.
Model 74 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
Winchester Model 74 .22 sr dating question ' The Firearms Forum
www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
Winchester Model 74 Value And Date ' Gun Values Board
www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
Jan 22, 2016 | Winchester Optics
When was my Winchester 94 30-30 made? Serial no. 2050464
according to this site it was made in 1954, I'm thinking that the the enter column # is the beginning sn for that year.
choose your model on the left,
then scroll down to 54 you will see the sn beginning in the 200's & in 55 the beginning sn in the 207's.
Serial Number Data
Feb 23, 2015 | Winchester Model 94 Short Rifle .30-30 20...
When was my WINCHESTER 30 W.G.F. SN 1312930 MADE.
Your Winchester 1894 was produced somewhere between 1943 & 1947. Winchester records for the years 1943 to1947 are not available. The last serial # shown for 1942 was 1221289. However, serial # 1313301 was shown in the polishing room in 1941. An valid supposition can be made that your rifle was produced after that. The last serial # produced in 1948 was 1500000.
Feb 10, 2015 | Winchester Model 94 Short Rifle .30-30 20...
Want year of Winchester model 64b
Production of the Model 64 began in late 1932, and two variants were offered; (1) the standard Rifle, and (2) the Deer Rifle. Many collectors refer to the Deer Rifle as a "Deluxe". Throughout its entire production, the Model 64 was serialized in the Model 94 serial number range. Production of the Model 64 ended in late 1957, with an estimated at 66,783 manufactured http://www.winchesterguns.com/support/files/images/wfa/2012-All/2012-Articles/Winchester-Manufacture-Dates-by-Year----2012-Scanned-Documents.pdf
Jan 22, 2015 | Winchester Optics
Need date of manufacture for Model 1917 rifle SN 4079800
It would depend on if it is an Eddystone (a subsidiary of Remington), Remington, or Winchester.
Don't think it's an Eddystone, as it's outside the serial number range.
Who was the manufacturer?
Mar 17, 2014 | Optics
What year was my Winchester 30/30 Land of Lincoln Model 94, serial # is IS194
Your best chance of getting an accurate answer is to take the Serial Number off the rifle and call Winchester directly. Winchester is Notorious for having problems dating some weapons because i believe they had terrible record keeping. Just call customer service and ask to speak to someone who can assist you in finding the year of the weapon they can look directly into the records and tell you year,make,model,caliber,and sometimes what MSRP was at the time the weapon was originally built. You can try the attached link to date it but if that fails definitely call Winchestor. I hope this helps you Kathleen Question 296 What year was my Winchester manufactured Serial Number...
Mar 05, 2014 | Sport & Outdoor - Others
Optics Logo
29 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you a Winchester Optic Expert? Answer questions, earn points and help others
