Question about Whirlpool Microwave Ovens
Burned a tiny hole in the microwave inlet cover of my whirlpool MH1150XMQ0? Is it safe to still use?
    Sergeant:
  • Whirlpool Expert
  • 448 Answers
Safe but will burn more replace wave guide cover common problem
in all microwaves grease build up on guide cause it to burn
SOURCE: microwave
check inside the microwave oven , at high voltage section wiring probem, change the wiring, and magnetron, other related spares.
Posted on Nov 04, 2007
SOURCE: Small 10 sec fire in microwave
Whirlpool had a recall on many microwaves due to this problem. Call Whirlpool and see if yours is one of them. My microwave model was mh7140xfb and was on the recall list.
Posted on Dec 29, 2008
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: whirlpool MH1150XMQ0
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download Whirlpool owner's manuals and installation instructions here.
Otherwise, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 31, 2010
  • 8909 Answers
SOURCE: This morning, while running the microwave, an
That is called the waveguide cover and it is there to stop moisture, steam and food particle from entering the magnetron or aerial and destroy the component parts.
There are spares available through Philips Agents or online from ebay or espares etc.
It is fairly innexpensive but essential!
Posted on Jan 03, 2011
Testimonial: "I haven't been able to find anything online for my model type, so I'll be visiting a local appliance shop tomorrow to see if they have any waveguides."
Why is there a burn hole inside the oven, on the cardboard?
That's actually a mica "window" (cover) for the microwaves to come out. And it sounds like the magnetron started arcing and burned a hole in that cover. Either that, or some food (frequently spaghetti sause) got splattered on it, and the microwaves heated it up so much that it burned a hole in the cover. Does the microwave oven still work (heat)? Do you see or hear any arcing? If the microwave oven still works and there is no arcing, you can just replace that cover. Check SearsPartsDirect.com or RepairClinic.com.
Jul 10, 2014 | Kenmore Microwave Ovens
Replacement of the Cover Inlet plate inside the microwave, this is part # 8184604. I have the part, I just need to know what to do to replace it. Thanks,
Hi
To locate the inlet cover, look towards the interior side of the microwave next to the microwave display. The inlet is typically located near the back of the microwave, in the middle of the wall.
Unplug your microwave from the electrical outlet and remove any food or containers.
Wipe the inlet cover, typically located on the right side of the microwave in the middle of the wall, with a damp cloth. The cover must be kept clean or it will not protect the microwave.
Dry the inlet cover with a soft towel.
Leave the microwave door open for several hours to air out the inlet cover.
Examine the inlet cover for wear and tear. If the cover has too much damage in the form of scratches or holes, it may need replacement.
Remove the inlet cover, if desired. Insert a putty knife under the plastic nail that holds the inlet cover in place. Pry out the nails and set them aside. Pull out the micro plate in front of the inlet and set it aside. Remove the inlet plate.
Install a new inlet plate. Slide the new inlet cover into its place. Replace the nails back into the side of the microwave by aligning them with the holes of the side.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 20, 2011 | KitchenAid KHMS145KSS Microwave Oven
A plastic container with hidden piece of metal caught fire in my Sharp r1490 and burned with a big flame. Several small holes were burned in the ceiling panel. Are we in danger of radiation exposure/ is...
The microwave oven is not safe to use, the fire has compromised the interior of the oven, if you run the microwave it will start to arc and eventually short out the magnetron, because the white enamel paint has been burned away. If you have holes in the ceiling there is danger of radiation leakage, for safety reasons the oven should be replaced.
Feb 23, 2011 | Sharp R-1490 Microwave Oven
This morning, while running the microwave, an interior cover overheated and scorched/burned. There is a hole in the upper right interior, where I believe the micro waves come out. This is a squarish...
Jan 03, 2011 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1150XMQ0 see sparks inside the upper right. Is this anything to do with the waveguide ? where is waveguide cover?
Jan 30, 2010 | Whirlpool MH1150XMQ Microwave Oven
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Jan 20, 2009 | Microwave Ovens
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
it may be ok , but it should be checked for internal damage
Dec 10, 2008 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
185 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
