Question about Yamaha Boating
I have a 1979 40 hp Yamaha 2 cyl outboard that I need to set the ignition timing and the accelerator link to the carburettor can any one assist with the procedure or specifications etc
  • 98 Answers
SOURCE: low idling on daihatsu charade 83 model
My first thouhts are your ignition is still your problem, but upu haven't made it clear if the problem exists only when the engine is cold.
On the Charde you must push the pedal down before pulling the choke lever for the choke and fast idle linkages to engage... then start the engine.
The idle circuit consists of an emulsion tube and a solenoid. The solenoid is on the back of the carby and has a green wire running to it. If there isn't 12 volts on this at startup you wont be able to get the engine to idle without pedal assistance.
The carburettor also has an acceleration plunger that squirts a shot of fuel into the engine when trying to increase speed. This has a concetrina boot that can leak. It is situated on to op the carby.
The vacuum hoses need to connected correctly, especially one of the distributor hoses. That one must be connected to AD port on the carby. The following diagram is one of my modified layouts, but should work satifactorily. It is configured so that you can set the ignition timing a little more advanced than factory. When you set the timing make sure both hoses to the dizzy are removed and blocked. You adjust the dizzy position until the dimple on the flywheel lines up with the notch in the timing plate above.
Diagram here
For a test try blocking the hose coming from the oil cap to the bottom of the carby. The cap is also a PCV valve and if it's not clean it can allow excess air into the engine at idle.
My feeling is your points gap is not correct. It should be about the thickness of a hacksaw blade when open. The rubbing block on the points is notorious for rapid wear if hi temp grease hasn't been applied to the rotor lobes. A small gap will cause arcing under load and not provided sufficient dwell time for the coil to charge, resulting in a weak spark, missing, over fueling and lack of acceleration.
I also recommend you replace the plugs with Bosch Super 4's. They will last you a very long time and tend to be very forgiving with older worn engines.
Posted on Oct 11, 2008
  • 120 Answers
SOURCE: I need a maual for a Yamaha 85 hp outboard motor 1992 model?
Hello nic nic 68, I know that a autozone will have the manual you are looking for. If you still need assistance please post again and i will gladly help.
Please post what you decide to do and how you do it. I look forward to your posts.
Posted on Nov 11, 2008
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
bytestream
  • 70 Answers
SOURCE: need firing order for a 86 chrysler outboard boat engine
Firing order 1 2 3 is common on most three cylinder outboards. 1 3 2 is the only other combination.
Posted on Jul 26, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
Hard starting on Yamaha 130 2 stroke. Always starts easily with ether. Choke works well.
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
Aug 02, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Yamaha 40 outboard stuck at full throttle won't idle
Sounds like accelerator butterflies are stuck,you probably need a good mechanic to sort this one out.try operate accelerator linkage on carburettors by hand but do not force, take off black air cleaner and spray penetrating oil onto butterfly shafts
Jan 27, 2014 | Clymer Marine Maintenance and Repair...
I need the torque specs for the big ends, crankcase and cyl. head of yamaha 90 outboard 1996
This will be a good source of info for Yamaha outboards: http://www.marineengine.com/boat-forum/forumdisplay.php?37-Yamaha-Outboard-Forum
Yamaha Outboard Forum
Jan 25, 2014 | Motorcycles
Yamaha 250vx cards outboard lost rpm wont go above 4200 rpm
clean and balance carbs , compressions all above 100psi ? sparks on all cyls ?
Sep 29, 2013 | Clymer Marine Maintenance and Repair...
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Nov 09, 2012 | Clymer Marine Maintenance and Repair...
Outboard 115 yamaha misfiring at low revs
Unscrew the 4 idle mixture screws 1/2 turn 1 at the time till sneezing stops...
Clean your carburettors
Oct 31, 2012 | Clymer Marine Maintenance and Repair...
Idleling only 2 of the 3 cyl. working if you open
I had one.....make sure the linkage is hooked correct. If it works when you do it by hand the linkage may not be working...??
Dec 09, 2009 | Boating
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Boating Logo
117 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
