Is possible to get the top baskets loose machine it self is functioning fine
I have a FAV6800AWC Top Load Maytag Neptune When in spin cycle you cannot keep it balanced, makes a banging soud (loud) and kickes washer off
It sounds like the spin basket rear support is loose. The support is part of the spin basket & does not come separately. This type of repair will more than likely need the spin basket replaced & possibly the outer tub also. It will cost you $200-300 to replace the assembly.
Hope this helps.
Shane
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Problem with washing machine spin cycle.
see if belt is loose if it is a no belt model you will need a repair man to change some parts
Mar 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine drum is moving about it still washes but it spins with a knocking sound
front load or top load?
top load - basket retaining nut loose or hub worn, possibly rusted through basket
front load- main bearing shot or pulley nut loose
Mar 07, 2010 | Washing Machines
Direct Drive Kenmore Washing Machine will not spin a full load of clothes during rinse or spin but will spin a small load. Agitates fine. Replaced drive coupler, clutch and basket drive...no luck. What...
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LSR7333 Top Load Washer
F51 & F72 Codes
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 70 Series
check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
might need a new one
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer basket has dropped 1.5"
Different models use different devices to "suspend" the tub. Please verify the exact make / model.
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle...
Sounds like the spin tub mounting block is stripped to me. Remove agitator. Remove spanner nut holding spin tub to basket drive. The block is the aluminum piece joining the basket drive shaft. The aluminum block has two square indentions that sit down on two tabs formed on the basket drive shaft. The soft metal wears out on the block and the drive shaft isnt attached to the spin tub anymore. An easy way to test is remove agitator and put in spin. See if shaft spins but not tub spin.Let me know what you find
Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
