Question about Samsung Televison & Video
Keeps turning off and saying FAN-CHK...... - Samsung Televison & Video
  • Samsung Master
  • 13,433 Answers
The dvd player is most likely overheating, turn it off for a while and make sure its not stacked with other equipment in a way that would prevent cool air getting to it.
Posted on Jul 20, 2009
How do i put more antifreeze on my hhr
How long does it run after shut off?Does it shut off at all or just run forever? If it ends up shuting off at some point after shut off, then I wouldnt worry to much bout it. The fan will run until the temperature sensor tells the computer that your engine is cool enough whether car is off or not. If it never shuts off then that'd be different : ) can honestly say I haven't seen that b4 but I'd say start at the temp sensor chk for voltage readings and see if they are within specs for your vehicle. Maybe sending constant signal to computer. Hope this helps you out.
Jun 28, 2012 | 2006 Chevrolet HHR
Home cinema shuts down after about two mins it says fan chk can u help
It means the fan(s) aren't doing their job. Clean out the dust bunnies and see if that helps.
Aug 23, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
The screen says... chk fan
Either the fan in your TV has failed, or the connection inside that allows your TV to recieve information about fan speed and operational state has failed. It needs to be serviced.
Jun 15, 2011 | Televison & Video
Samsung Theater System keeps flashing 'fan chk' when I turn it on and then shuts down two minutes later. The Fan is spinning. Does the fan need to be replaced, or is somthing else wrong with the unit.
When it tells you to check the fan it mans the device is overheating.
you can try buying a air spray and spraying it into the device/use a vacuum cleaner on the fan ports in case there is dust blocking the system
Mar 07, 2011 | Samsung Theater System
My Samsung HT-WZ410 home theatre keeps saying fan chk, then shouts down, this has never happened before
I've advice you to check your exhaust fan if working properly.
The processor shuts down the unit because it sense that you have a problem on the fan.
This is happen to avoid further damaged to your output I.C. which is quite expensive.
If the fan is not working then try to clean it, sometimes it is full of dust that caused to stop from functioning. If you confirmed that the fan is already defective then replaced it with a new one.
After replacing and the symptom is still there then I've advice you to look for a qualified technician because there might be sometime wrong on the board (faulty parts).
Pls rate my help.
Thanks for using fixya...
Jan 15, 2011 | Samsung HT-Z310T Theater System
Fan is not working
You can chk. Rad. fan fuse/Relay, Then u can chk. Cooling fan motor, coolant temperature sensor.
Nov 22, 2010 | Hyundai Elantra Cars & Trucks
It keeps overheating and its not caused by radiator i think its the water pump how do i (diy) the problem
is ther water leaking out of the pump if not then change the thermostat make sure you place it back in the way you took ou the old one , also simple chk turn on key dont start put ac on max see if coolant fan comes on if not then chk relay for cooling fan
Jul 19, 2010 | 1997 Dodge Caravan
Fan chk problem too
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jul 04, 2009 | Samsung HT-Z310T Theater System
Televison & Video Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
