WHERE can I contact you? Physically - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 50,335 Answers
Sorry but no sure why you would need this . we the people that answer questions live all over the world .and give free advise when we can .
Posted on Dec 05, 2016
2001 odyssey. Can a badly worn ign key cause the immobilizer to make the van stall out?
In my view, unlikely. The immobilizer works from the chip in the key and the chip in the ignition lock. They are a sealed unit. The only way would be if the key has been physically damaged or cracked. If the key is worn, perhaps the contacts in the ignition switch are worn and not making good contact?
Mar 11, 2018 | Cars & Trucks
The power button is broken how to turn ontv
Hello Andrew
You didn't specify what you mean by "Broken"
Do you mean physically broken or
It just doesn't turn the tv on?
There are separate answers for each.
1:To fix a physically broken switch you could simply open the TV up and attach 2 wires to where the switch contacts are soldered to the PCB.
Run the wires to a new switch. Probably a NO (Normally Open) type. A Round switch could be mounted easily with a drill hole through an unused area of the case. Pressing a NO switch closes the contacts momentarily to trigger the digital turn On.
2:You could remove the old switch & attempt to get an actual replacement or a similar mountable switch from a components supplier.
3:If the switch is actually physically OK and the internal contacts are working (test with multimeter) then the problem is with the digital switch mode power supply that supplies power to the main circuits.
This would probably be caused by leaky Electrolytic Capacitors on the power supply PCB.
In that case, if your up to using a soldering iron and locating the Cap's then this would be an inexpensive way to fix the TV.
Good Luck
Switched mode power supply
Capacitor Replacement Tutorial
How to Replace an Electrolytic Capacitor
Apr 05, 2016 | Televison & Video
My lenovo enter button does not working please suggest me
If it's physically broken, in some cases, you can push it back into its place. If it's NOT broken and can still (physically) be pressed & released like it normally does, then problem is internal. Either way the entire keyboard module will have to be replaced.
You can contact Lenovo for a warranty replacement if it's still in warranty. If it's out of warranty, you can purchase a replacement keyboard module (usually around US$30); It can be purchased from their spare parts website but if you do not know the part number, call tech support & provide them your computer's Serial or Machine Type numbers and they can locate spare parts and prices for you.
Aug 14, 2011 | Computers & Internet
Not works, is not posibility for open and fot see in the switch contacts, & IM
You cannot physically see the switch contacts, they must be measured for continuity.
I suggest a Microwave repair man would be a good idea at this point.
Jan 02, 2011 | Microwave Ovens
Can't press talk button and therefore can't get dial tone
If the button is physically there it may be that the contacts underneath are dirty. You can take the phone apart " usually pretty simple " and then clean the contacts where the buttons press with some rubbing alcohol, let it dry and re-assemble the phone. If the button is physically gone, missing, or damaged you may be better off buying a new phone.
Jun 09, 2010 | Panasonic KX-TG2313 Cordless Phone
How to get music from computer to xbox?
Please read everything before you do anything, thanks.
I assume you are trying to link you pc and Xbox. Here’s how I did it:
1) Disconnect your modem from your router, physically.
2) Disable the internet security on your pc, ***PLEASE NOTE: disabling security leaves your pc vulnerable, make sure you are physically disconnected from the internet.***
3) In the Xbox dashboard go to my Xbox, then music library.
3) Select the pc option, at this point the Xbox should automatically sync with the pc.
-----THIS IS NOT THE INSTRUCTIONS GIVEN BY XBOX, USE DESCRESSION WHEN ATTEMPTING THIS. It worked for me, but I was syncing to an old pc that doesn’t store sensitive data or matter if gets ruined. In no way do I suggest trying this with a new or important pc.-----
You can also contact www.xbox.com and click contact customer support.
Good luck.
Mar 04, 2010 | Microsoft Xbox 360 Console
Can't find radio fuse
please rate highly if this helps.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
battery box is under hood.
CJB is on left side of dash
May 10, 2009 | 2001 Ford Taurus
My lop tap is getting no internet connection
I probably can help you but would need a little more info. Are you trying to connect via wireless? Are you physically plugged into a router or directly to a DSL type box? Have you contacted your provider?
Jul 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
