Question about Jacuzzi Home
Need indicator rings for 3 controls on U640959 Jacuzzi bathtub. These are flat rings 1.5" ID, 2" OD. The two for the air have 5 circles. Also need the on-off ring.
  • 3,052 Answers
Good luck Scott Jones...
I've been looking for some specifics on Jacuzzi (seacrest) faucets... for a couple of years...
Since before Jacuzzi moved out of the EAST-BAY area (here) they had pretty good stuff.
I have their "washerless" ceramic faucets..
Through trial & error I've been able to keep these working...
No thanks to the so called "Jacuzzi" (moved out of CALIFORNIA).
Not only were they not helpful when I told them I didn't want their NEW STUFF...
I only wanted to service what I've had for 30 years
(controls sound like what you have)
Try calling these folks... At least they know what JACUZZI used to mean... GOOD STUFF:
Jacuzzi of El Cerrito ... (510-) 527-5547
5327 Jacuzzi St Ste 2c,
Richmond, CA 94804
Toll FREE... Call 888-738-5523
Hope this helps.
Hot Tubs Swim Spas Saunas in California Sales Service Paradise Valley Spas
Jacuzzi Whirlpool Bath JWB 1 2 Air Volume Control Elbow PA54000 U775000...
Posted on Dec 05, 2016
How do you replace jacuzzi 3 Position Control Panel Kit?
here is a sheet with instructions that show how to remove the graphic rings that hold the buttons in place.
Aug 15, 2014 | Jacuzzi Home
Jacuzzi tara o ring
What is the o-ring used for? Where is this o-ring located and what is the function of the o-ring?
US Parts Center
Mar 09, 2014 | Jacuzzi Tara, Whirlpool Bath -...
There are holes where rats chewed through in the air tube connected to the motor. How long is the tube and is it easy to replace? I would look myself but I'm afraid I might hurt it more. I believe the...
Zit tubing connects to the underside of the air button to the air switch on the motor. Younshould not need anymore than about 5-6 feet. Available at your local hardware store. Ask for 1/4" hose OD
Feb 14, 2011 | Jacuzzi Home
1980's jacuzzi bathtub, won't turn on (seems to be the kind when you push a button in to turn on), no outside electrical panel, no clear point of access (tiled on side of tub) - where do we start?
you will need to open up the back of the tub where the pump is and see if there is a clear tube about 1/4" OD attached to the backside of it close to the pump cord.
If it is there then you will need to check out the air switch on the motor that the air tubing attaches to to see if it is good. If it will activate the pump when you blow into it with a straw then the air button on the top of the bathtub is probably bad and needs to be changed. if it does not turn the pump on/off when you blow into it then you will need a new air switch.
Jan 23, 2011 | Jacuzzi Home
What do the arrows on the jacuzzi luxura 530 control
Arrows on the control indicate up/down temperature or on/off on the air control.
Jan 13, 2011 | Jacuzzi Luxura, 530 Whirlpool w/ Integral...
Jacuzzi had not worked for about 2 years. I took the door off to check for moisture and I noticed the air switch was disconnected. I replaced the switch and the motor ran for about 2 seconds and stopped....
sounds like the air switch didn't latch. you may need a new air switch in the motor to make it work again.
the way to check this is to remove the pump. plug it into an outlet and take a straw and blow into the air switch on the motor. if you can get it to come on then the air button is bad on the top of the bathtub. if it will not come on/off then the air switch is bad on the motor.
Jan 04, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi whirlpool bath not working when i turn it on i get a buzzing sound
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
Dec 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Aug 02, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi tub on/off bezel wont hold switch down
I couldn't find the information you are asking for in the installation manual. I have included a link to the pdf page so you can print it out and look at it in print. On this particular question, I think I would give Jacuzzi a call. They can better answer you question without guessing.
Mar 22, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
147 people viewed this question
Top Jacuzzi Home Experts
john h
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
