Question about Irons
I have a new steam iron. I cannot uwe tab water because my house water is softned. What kind of water should i use?
    Master:
  • 507 Answers
Any distilled water will do even if its bottled distilled water (even boiled water will do after its cooled down to avoid damaging the steam iron)
Posted on Dec 05, 2016
Steam stays on all the time
the valve is jammed
you live in england
so... take a calgon tab
and make up some boiling water
add the boiling water to fill the iron half way
now make up a paste with the calgon tab {a bit of like 1/8th}
add this paste to the water chanel of the iron
and then using a fresh boiling water
water it in
to fill the iron
let it sit for two mins
then exercise the valves for steam and water
and tip the iron front and back
let it sit a further 2 mins
NOW
plug in the iron and set it cotton number 1 {40deg usually}
let it sit and hiss
and steam it thru again exercise the valves
youll also need to make sure the holes on the base of it are clear
you can also leave the botton of the iron in a small tray of a calgon tab
this disolves all the lime scale and will bring perhaps
a sad iron or etc back to life again
after a good rinse thru reuse this treatment every few months
hey i live in glasgow so unlike the limes our water is pure gold
no lime ...
Jun 04, 2015 | Irons
Constantly producing steam
I do not recommend irons to be fixed. You cannot find spare parts (you have aged seal) and any kind of a fix can be dangerous on some stage, just because elecftricity and water are very bad combination in any aspect. To prevent yourself from electric shock or burning your house, just buy a new one. Be sure not only the seal is aged when you open the iron for repair, if you succeed with the strange shaped bolts. Then broken parts are hard to glue just because the iron is heating up above the point most of the glues can hold. So, spear your time, cut the cable and leave it on designated place for collecting electric rubbish. Then go for a new one.
Oct 09, 2014 | Irons
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
How to flush brown fluid from Sunbeam Steam Master steam jets and increase steam shooting?
There is commercial iron cleaner, but you can use white vinegar and distilled water to flush it. I would use a mixture of half and half. Then let it steam its little self, when it is clear, rinse with the distilled water again, This kind of thing happens when you use tap water and let it sit in it without rinsing after using. I always use distilled water and empty right away after use. Good luck
Nov 02, 2010 | Sunbeam 4214 Iron
What kind of water should be used in a Rowenta Titan Plus
It is always recommended to use distilled water for steam iron in general.
Second best is clean rain water.
For an expensive iron, I would not use Tap water as it has too many residue/mineral that will eventually cause brown/dark stains spots to be ejected from the steam iron pores!
You can buy 'bulk' distilled water for ironing from most supermarket and departmental stores. You can also use pure distilled water for car battery topping but auto shop tend to charge a premium for it!
Hope the information is helpful!
Hope the information is useful.
Sep 24, 2010 | Rowenta Professional DX8800 Iron
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Water type to use in an iron
You should always usw distilles water in an iron. This prevents scale and crud from clogging up you water and steam ports. I hope this helps. Don't forget to rate my answer.
Feb 07, 2009 | Irons
Irons Logo
140 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
