FM1000 CONNECT WITH TELEVISION - Televison & Video
Westinghouse TV won't connect to Internet how do I do this
First, is it a smart television that has internet connectivity? Westinghouse are a budget brand although newer ones are big and have Ultra HD 4K..
Connect your PVR, Cable Box to the Router. Connect the television to the PVR Cable Box. Or connect the television direct to the Router. Or your television may have wifi enabled. Go to settings and Internet, or Smart Hub or whatever they choose to call it on the television. Add your Connection name, (mine is Bell895) and then the WPA2 password to the Router which is normally on the Router itself or the paperwork that came with it.
Support WE
Jul 04, 2017 | Westinghouse Televison & Video
1. Buy a monitor to computer cable (VGA cable),
2. Connect one end to the television,
3. Connect the other end to the computer (video port),
4. Turn on both of the television and the computer,
5. Select the television input (VGA or XGA) using the television's remote control device.
Dec 25, 2013 | Sharp Televison & Video
Hooking up antena & converter box
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Dec 02, 2012 | GE 27GT271 TV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
TC-P50GT25 Viera has no audio out put.I need to connect surround sound.
In that case all you can do is connect each device you're connecting to the television to the surround sound. You would connect the device to the television for video only and connect the sound cables to the surround sound. You may also be able to connect the devices directly to the surround sound (video and audio) and then connect it to one of the television's inputs.
May 07, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
How to connect my Vizio vsb200 to my sharp lc-42sb45ut?
This television does not have audio outputs so you wouldn't be able to connect these two devices--well the one digital audio output this television has is not compatible with any of the inputs on this Vizio. Double check please by looking for a hole/input on the Vizio that will match up with that on the Sharp television. If I am wrong and there is one then you would need the digital audio cable. I believe this television takes a coaxial digital audio cable, and the hole that would correspond to this cable on electronic devices is normally black in color.
If I am correct and there is no way to connect these two devices directly then you would connect your devices to the Sharp television for video only and connect their audio cables to the Vizio's inputs.
Mar 08, 2011 | Sharp Televison & Video
When you connect the HDMI cable from the TV to the receiver, is the receiver to and the TV to work pr is some other connection needed?
You can't connect your receiver to the television to get sound that way unless your television has an hdmi output. Your tv more than likely does not have an hdmi output. Those are hdmi inputs on your television. The way to connect the television to the receiver is to connect the red and white RCA outputs from the tv to the red and white RCA inputs on the receiver to get stereo sound. Now if your television has a digital audio out you might be able to get surround sound with connecting a fiber optic cable between the digital audio out of the tv and the digital audio in on the receiver, but this does not always work for all of the devices you have connected to your television.
The way to go is to connect all of your devices to the television's inputs for video and directly to the receiver for sound. The devices are connected from their audio OUT to your receiver's audio IN.
Feb 05, 2011 | Sony STR-DH510 5.1 Channels Receiver
How Do I Connect the DVD to my TOSHIBA 36A43?
You get the red, yellow and white, then you connect the red to the audio out of the player and connect it to the audio in of the television, then you connect the yellow prong to the video out of the player and connect it to the video in of the television, then you leave the white free.
Put your television on AV mode and you will be able to view movies from the DVD player on the television.
Hope this helps.
Take care and good luck
Jan 10, 2011 | Toshiba 36A43 36" TV
How do I connect my computer to my tv so I may view internet on my tv?
To connect your computer to your television, you will have to get the VGA cable for your computer and connect it to the back of your television, then you connect it to the inlet/port that is on the computer, that is the port where you connect your monitor, then you go to your television and select the AV mode, then you will be able to view your computers work on the television.
Dec 12, 2010 | Vizio VF551XVT 55 in. HDTV
Connecting my DVD Player to my Digital Converter Box
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
Feb 01, 2009 | Coby DVD-224 DVD Player
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
