Where can i find a manual for a Craig CHT909C Tower Stereo System w/ lights and usb and sd card slots
  • 31 Answers
SOURCE: Cannot detect SD flash memory
check in "my computer" and see if it registers as a removable drive there. If not, then check in the device manager while the card is inserted and look for any yellow icons. There is a chance that the card reader need a driver installed or updated.
Hope this helps.
Posted on Mar 30, 2008
  • 94 Answers
SOURCE: SD Slot doesn't work
If the SD card is a high capacity card (SDHC) the SD slot may not be capable of recognizing it. Suggest to try another SD card. If that still doesn't work find the drivers on your laptop manufacturers website.
Posted on May 11, 2009
  • 136 Answers
SOURCE: My computer does not recognize my SD 2GB SD Flash
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Posted on Jun 25, 2009
  • 32281 Answers
SOURCE: SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Posted on Aug 14, 2009
SOURCE: sd card in cd slot of imac desktop
Use a large paper clip and fold it shaped. Gently insert it into the cd slot and drag the card out. My kid has done it twice so far. Make sure the power is off and if the clip hangs, don't pull.
Posted on Feb 19, 2010
Testimonial: "can't get a hold of anything, still trying thanks!"
What is the biggest SD card Craig 7" netbook model # clp281x will hold
this unit can be upgraded to SD/MMC Card Slot (Supports Max. 32GB).
provided a link for your refrence.
Refurbished Craig CLP281 Black 800 MHz 7 256MB DDR3 Memory 4 GB Built in...
May 05, 2016 | Computers & Internet
Where is the slot to put my camera scan disk in on Gateway sx 211ogwu23 computer??
All the slots USB, audio, etc are located at the bottom left of the tower.
If no SD slot is available you may need a card reader that connects to the computer via the USB slot
Why not contact support for further help
Contact Support
Oct 16, 2015 | Gateway Computers & Internet
Power will not come on. Indicator light is off as well.
Sounds like you have a fuse problem. Check the fuse and if that;s not it then more than likely you have Problems in the power supply. It should have a year warranty on it. I would take it back.
Mar 12, 2014 | Craig Electronics CHT909c Tower Speaker...
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
how do you set the sd card back to the begaining without the remote?
Dec 29, 2012 | Craig Electronics CHT909c Tower Speaker...
How do you transfer a photo from computer to sanDisk
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
Jun 08, 2011 | SanDisk 4GB microSDHC Memory Card
Where do i put my mamory card in my computer?
Dear princess,
what type of computer do you have???
Look for slots some are marked SD,,,,,,,PRO,,,,, If laptop check sides... if Tower push on front panels near DVD player they will flip open....
Nov 27, 2010 | SanDisk 2GB microSD Memory Card
My sandisk wake ur phone up adapter 4gb isnt workin in the card slots on the tower
Please bear in mind, that 4GB cards will most likely be of the newer SD HC (Secure Digital - High Capacity) standard, which is not recognized by older devices that only support the basic SD specifications.
You have to try a 2GB card, or look for a non-HC 4GB card, but these are very hard to find.
Jan 12, 2010 | SanDisk 2GB microSD Memory Card
Lexar 2gb sd
its having problem with its chip...claim forwarranty....
Reply if satisfied
Jul 06, 2009 | SanDisk 2GB microSD Memory Card
52 people viewed this question
