Question about Kitchen Appliances - Others
IF wacker compactors motor stop accidentally with out notice what should i do.
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
My ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
Dec 11, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
My KitchenAid trash compactor model KUCP021RBL1: cycle does't end
Most likely the motorwindings have been overheated after staying to long time in down position and trying to get up.
If there is a Emerson motor in your compactor than you will not find anything wrong most likely it is the winding of the motor, we have had this two times, changed the motor and the problem is solved.
Kind regards,
Paul
Netherlands
Dec 30, 2008 | KitchenAid P Series Trash Compactor -...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile compactor
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Aug 19, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Jul 13, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kitchen Appliances - Others Logo
62 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
