Question about Tablets & eReaders
My nook boos on ,y nook r off center an i cantfix
How do I transfer my library on my old Nook to my new Nook?
How to transfer books from old nook to New Nook? Therefore, to transfer your Nook books to a new Nook, all you have to do is perform a synchronization between the Nook and your Barnes and Noble account. Press the "Power" button on your Nook and hold it down for two seconds to turn on the device. The Welcome screen opens.
How to Transfer Nook Books to a Different Nook ' Chron.com
smallbusiness.chron.com/transfer-nook-books-different-nook-27403.html Search for: How to transfer books from old nook to New Nook?
How do transfer my library on my old Nook to my new Nook Google Search
Feb 07, 2017 | Tablets & eReaders
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Will not take a charge a
Barnes & Noble Nook HD
Jan 01, 2016 | Barnes & Noble Nook HD
Have downloaded e-books from the library, but can't delete them from my Nook.
For some books, downloaded from your PC, the only way to delete them is to attach the Nook Simple Touch to your PC and open the Nook Simple Touch on the PC. (For a PC, open the computer icon and look for the Nook icon and click on that.) From your PC you can delete files from the Nook Simple Touch or move them off the Nook Simple Touch to your PC.
IF you have a MAC or if my advice doesn't work, you should contact the Nook support. It is at the Nook website. Click on Nook and look for Nook support.
Jul 30, 2015 | Barnes & Noble NOOK Simple Touch eReader -...
Nook tablet service center in hyderabad
Naresh,
This is a sign of a bad battery. I would say replacing the battery should correct the issue.
Dec 29, 2014 | Barnes & Noble NOOK BNTV250A 9781400501779...
Problems with my nook
Nook is among the most popular e-Reader devices after Kindle. If you are using Barnes & Noble Nook and facing a certain issue in the device, then you have to take Nook support. If you find nothing useful on the website, then Call Toll Free No. +1(844)-305-0086
Aug 26, 2014 | Barnes & Noble nook color eBook Reader
Why my nook tablet will not turn on ?
If the screen is off and won't turn on, make sure the battery has a charge. Plug in your device for 30 minutes before trying anything else. If it is on or if the battery has a charge you may need to "hard reset" the Nook. Although this is very uncommon, it may happen. Below are a few solutions that may help.
  • Hold down the power button for 10-15 seconds. The Nook should power off and you can turn it back on again. Everything should work normally.
  • If that does not work you will need to hold down the power button and the "N" button for 10 or more seconds. Again, this should force your device to power off and you can start it up normally.
  • Take out the N2A Card and try the same steps again. Your Nook should boot up into Nook mode. You'll have to restart it again with the N2A Card in to boot up in Android mode.
One of the tasks above will usually correct this issue unless you have a hardware problem with the Nook. Our cards cannot cause hardware problems unless they are forcefully inserted wrong. If you determine you do have a hardware problem you will need to take the Nook back to the retailer if it is still under warranty. The Nook usually comes with a one-year (non-accidental) warranty through Barnes & Noble. Some retailers, like Best Buy, exchange them in the store under warranty.
Don't forget to hold onto your N2A Card until they return your Nook!
If you still have any kind of issue thenhttp://www.tablethelpline.com/nook-support/ you can take Nook Help from experts by calling nook customer service number.
May 16, 2014 | Barnes & Noble nook color eBook Reader
My Nook Library has disappeared on my Nook-how do I restore it?
Download all the archived and unarchived books and save them to your computer. Never deleted these.
You have two options for the archived books.
Un-archive them and they will appear on your nook and download as you see fit.
OR... Sideload them. Which is probably what you did before since archived books already disappear from your My B&N Library and would have had to be in your My Documents Library.
Not exactly sure what you mean by 'does not go to my nook' when you try and save/download from the website.
If still having any kind of issue then you can take nook support from experts or call nook help number.
Mar 24, 2013 | Barnes & Noble nook color eBook Reader
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
