Question about Watches
My morphie powerbank won't charge my iwatch. Works fine for my iPhone and iPad My old Duracell powerbank charges the iwatch ok?
I was sent to this sight and I hope to get help. Do I charge my Apple Watch battery on day of purchase and for how long?
Hello Tyrone Steele,
Reading your OWNERS MANUAL is always your best option...
But if you are talking about iWatch
instead of the simple APPLE WATCH
(quartz movement... ordinary watch battery = no charge)
You can go to APPLE.COM to see
additional options available
Apple Watch Magnetic Charging Cable 1
Carnac the Magnificent
Mar 16, 2017 | Watches
Is the cicret bracelet fact or hoax?
Would be more of an Apple watch. An iPad should be bigger then a iPhone. The smaller version now is called iPod.
Almost all Apple iOS devices can do the same (Or you can) only the name gives a hint of the size.
Jan 18, 2015 | Watches
Why won't my "solar" powered watch charge/work any more?
Some of these eco-drive watches use a swinging weight self winding mechanism (albeit through a generator) or a solar cell under the dial, some use both. Either way the capacitor is the thing that holds the charge and once that fails it will need replacing. Sometimes not as straight forward as replacing a battery as you nay have to remove the auto weight and sometimes usually on the solar ones its just a case of popping it out and a new one in. They are quite difficult to identify and get hold of but they do differ from normal batteries as they come with 1 of the contacts attached to them to prevent fitting an ordinary battery by mistake
Feb 02, 2013 | Citizen Watches
Burg watch phone will not take a charge
Have the same problem.
I tried to warm up the watch phone by putting it in the sun for some time and then trying to charge. this procedure sometimes works for old batteries.
But, did not work in my case.
Hope you are lucky.
Oct 20, 2012 | Watches
How do i recharge a watch pansonic battery mt 516
My watch was in the drawer for over a year and stopped working. I flashed my iphone torch directly on it for literally about 3 minutes and BRAVO it's working again.
Oct 09, 2012 | Watches
Watch runs ok in the light but stops in the dark.The watch is 14 years old
the battery is not holding a charge. replace the battery or sleep with the lights on
Jan 14, 2011 | Citizen Eco-Drive BL006056H Wrist Watch
It wont charge
mcdevito75 here, Possibly the battery is worn out. An old battery will not hold a charge, Visit a small watch repair shop in yourarea for a new battery.
Jun 28, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Eco-drive BT0054-59E not charging.
I know what the manual says, but I have found that sometimes it can take a few days to charge.
I set mine directly under a UV lamp for at least a day to charge. I have found the PULLing the STEM OUT and setting it under a lamp to charge works the best. Try for a couple days, one day stem out another stem in.
If it still does not charge it may need a new secondary battery.
Citizen offers a good warranty on that secondary battery/ power cell and if it's just a few years old they should replace it for free.
This really is not something you should try to fix yourself as the cells are easy to mess up.
Good luck.
Oct 23, 2009 | Watches
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
26 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
