Connect fc 1000 to 32in television - Televison & Video
How do I connect the coaxial cable?
This is quite simple. Your wall box is a male connector. The TV input is a female one. Make a cable with resp; female and a male connector. Unless the wall box has a 'screw on' connector. (FC10 f.i.) Then you need this special item and/or crimp tools in order to fit this FC type connector to the coax cable. Not simple.
Oct 12, 2014 | Televison & Video
HELP fc rvasd
What is the problem you faces with this TV. Provide more details please. google.com/+GopakumarGopalan
Nov 01, 2013 | Supersonic FC-2245 13" TV/DVD
Connect sony wega connect
0328,0312,0376,0000. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 27, 2013 | Televison & Video
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
TAPE LIBRARY PROBLEM
As I understand it, the SNC is basically a Fibre/SCSI Bridge... and what you are seeing is the FC light being on means that the SNC is connected to the Fibre SAN... but there drives aren't connected to the bridge. Check out http://downloads.quantum.com/scalar/S24/omUsersGuideSNC4000.pdf for information on how to connect to the SNC and run the discovery process. You'll most likely have to connect via serial connection, and the document I included does a great job of discribing that process. I'd suggest that you request an IP Address from your IT folks beforehand, so that you can configure it on your IP Network whaile you're at it.
Jul 24, 2007 | ADIC Scalar 24
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
