Question about Microwave Ovens
Sparks form the right side inside the microwave
  • Microwave Ovens Master
  • 3,093 Answers
Hello Jeffrey Genser,
Make & model would be really helpful...
But it matters not: I can SPECULATE with the best of them.
Specific to most microwave instructions is the CAUTION not to run the MICROWAVE with nothing (or very little) in it.
The magnetron (generator) will simply absorb it's own energy
and self destruct... If you have kids that like to warm individual pats of butter... Expect that unit will soon FAIL.
Likewise if you have kids (??) that think it's cute to
microwave DVDs or CDs... tin foil or any of the zillion stunts
un-developed minds are apt to engage... EXPECT the MAGNETRON to soon fail.
Sparks will be seen from the area of the magnetron.... before the FUSE finally OPERATES.
SUGGESTION ... If you MUST soften a single pat of butter
put a bowl or cup of water next to it and add a few seconds to the timer...
Your WALLET will be much happier.. and your microwave will still be there when you need it.
Hope this helps.
Posted on Dec 05, 2016
    Top Expert:
  • 49,228 Answers
Take it in for a proper diagnosis
there are to be no sparks from a microwave inside or outside
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Fire sparks when in use off pad on right side of microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 09, 2010 | Dacor DMT2420SS Microwave Oven
The silver fiberglass plate on the right side of the inside of my microwave has gotten a hole in it, causing the microwave to spark. Is it possible to replace this part? I have had the microwave less than...
yes you can buy a sheet and cut it to size-just ensure that any bare metal inside the microwave caused by the sparking isrubbed down and painted with two coats of ,hammerite metal paint otherwise its back to square one
Feb 25, 2010 | Emerson MW8107WA Microwave Oven
My microwave does alot of sparking around the small pad inside the microwave on right side . model # jes1290ml01
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
t
Dec 08, 2009 | General Electric Microwave Oven
Microwave sparks on the inside
It sounds like it needs professional servicing. There may be an issue with excessive radiation escaping from the oven -- this could be dangerous. Can't say for sure, but were it my oven, I would take it to a shop with the equipment to test for this condition.
Charlie
Aug 23, 2009 | Microwave Ovens
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore 1200 watt sparking when warming empty plates
Unless specifically stated in the manual, you shouldn't use the microwave for warming plates. That is not it's intended use.
I suspect the microwave circuit has failed in some manner.
Reply the specific Sears model number (in the form xxx.yyyyyyyy), and I can help further.
Jan 23, 2009 | Kenmore 63252 Microwave Oven
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Microwave
check inside the microwave oven , at high voltage section wiring probem, change the wiring, and magnetron, other related spares.
Nov 03, 2007 | GE Advantium SCA2001BSS Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
