Question about Dishwashers
I have a Dishlex Global 300 DW. The Mains safety switch trips on Rinse cycle. Heating element has continuity and works on wash cycle. There are no leaks.
    Top Expert:
  • Dishwashers Master
  • 51,337 Answers
Call an electrician to check the insulation for ground leakage and breaker capacity for current use
it will most likely be tripping from moisture across the active and neutral wires somewhere
Posted on Dec 05, 2016
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 310 trips the circuit breaker at any time during wash. Fitter an RCD to the power point .. but problem still happens . Any ideas ?
?? would have to see d/w to help with this problem .. could be a bad breaker / if its not the dw .. should call a service tec .. mm
Nov 20, 2009 | Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
Dec 09, 2007 | Dishwashers
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
