Question about Sony Office Equipment & Supplies
How to get hidden menu in sony projector??
My projector is sony es5
2 Suggested Answers
gopakumarg43
  • 75311 Answers
SOURCE: svga vlp - es5 projector control key locked problem
Hello
Your projector is in security lock Enabled condition. If you have forgot the pascode . You can change the password by
Use the Menu'UP'/'Down' '<'/'>' buttons to enter the four digit pascode. The default password is "ENTER,ENTER,ENTER, ENTER". After this is entered, you can put in a new pasword. Therefore when you use this function for the first time, pleas input "ENTER" four times.
To cancel the security lock, press the Menu key, then turn OFF the "Security Lock" setting on the INSTALL SETTING menu.
If you call the customer service center because you have forgotten the password, you will need to be able to veryfy the projectors' serial number and your identity. The process may differ in other countries/regions. Once your identity has been confirmed, they will provide you a password. OK.
Posted on Oct 22, 2011
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    Green light is continuesly bling but the projector is not given the display
    1,Check the fans ,whether each fan is running,when you turn on the projector
    2,if the fans run, then ,check the lamp or lamp ballast
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Jerry
    Lampdeng Limited
    Dec 11, 2014 | Sony VPL-BW5, VPL-ES5, VPL-EW5, VPL-EX5,...
    How do I fix Lamp/Cover flashing light?
    There is a switch or a button that gets depressed when you close the lid of the lamp compartment. See if the plastic of the lid is broken or not hitting it right. Not screwed down right or the lamp is not seated all the way down.
    Dec 20, 2012 | Sony Office Equipment & Supplies
    Svga vlp - es5 projector control key locked problem
    Hello
    Oct 22, 2011 | Office Equipment & Supplies
    Sony projector vpl ex5 yellow display problem
    try replacing the bul/lamp.
    warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
    May 21, 2011 | Sony VPL-EX5 Projector
    Hi My Sony VPL ES5 SWITCHES OFF THE LAMP AFTER 2 MINUTE
    hi your projector probaly has done around 2122 hrs on the bulb just reset the lamp timer and you should be good to go ps this worked for me (answer yes to replace bulb and clean filter then press ok pps might be a good idea to start saving up for a replacement bulb hope this helps cheers !!!
    Aug 24, 2010 | Sony VPLES1 Projector
    How to disable power on password on Sony VPL-ES2 LCD projector?
    Hi there! I'm assuming you're able to enter the password so that the unit comes up...Go into the menu selection called "Initial Settings". Choose the option called "Security Lock" and pick the "off" menu item. Exit out of the menu and power down the projector. Re-start the projector and it should have no password activation. If you need the user manual, let me know...Hope I assisted you successfully!--Rick
    Sep 09, 2009 | Sony VPL-ES2 LCD Projector
    Sony VPL-CS5 menu will not display
    Give input signal to the projector and see that if the menu appears or not on the screen.
    if menu comes on the screen then put the backgroung color to blue, instaed of black.
    if nothing comes on the screen, then the LCD panels are faulty.
    Viren
    RAVE SERVICES
    Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
    62 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
