What software will edit the data1.dat file on a Amp'd Maxxpro? This file has the owners name and the timer showing how many days before player will disable itself. The characters look like Chinese.
SOURCE: How do I edit the file names so songs by the same artist can be in the same folder???!
then the problem is not the mp3 player but your files. They are probably marked as read only. This usually happens if you copied them from another media like mp3.
Right click over the folder holding them, choose properties. In the new window you will seee an attribute called read only ticked. Untick it. Press OK. The computer will ask if you want to repeat this on all sub-folders. Choose Yes. This will allow you to edit your files.
If you have music files with Digital Music Security (DMS) you wont be able to edit them. Better to re-download them using p2p software.
Posted on Feb 16, 2008
  • 8596 Answers
SOURCE: Device doesn't recognize my 2gb expansion card anymore.
stilts - this player can't actually handle an SD card greater than 256 MB unless the player is largely empty - sad but true
everyone else -
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
SOURCE: Chinese Digital MP34 Player/ iTouch knockoff...
i don't no
Posted on Jul 03, 2008
  • 1800 Answers
SOURCE: mp3 play changed over to chinese
u shud change it language parameters to english!
check the settings its like awrench key icon
Posted on Jun 28, 2009
  • 496 Answers
SOURCE: dat file
first you should try and locate the files on the mp3 player all the music and whatever else is on there and back it up to the hard drive, then goto the rca website and find the latest firmware for your player and download it and reload the firmware that should get everything back to factory defaults
Posted on Oct 05, 2009
How to change a Dat file so I can open it on my Samsung tablet
DAT is a file extension that's mostly found on video CD. It is usually used to store MPEG-1 encoded video on VCD. This kind of video file is file format that are not playable in the default Android video player.
But don't worry, there are ways to make it playable. In this article, I'll show you how to play DATvideo file on your Android device.
To be able to play DAT video file in your Android device, you should need the help of a third-partyvideo player app. In this case, I suggest you to use MX player.
MX player is one of the most popular video players that can play almost every video format. It also play all resolutions that supported by your device.
If you don't have one, you can download it for free at Google play store.
Once installed, open the DAT video file with your file manager app and the video should be loaded and played by the MX player. However, you're unable to load DAT video file on 'My files' or 'Gallery' app, as well as 'MX player'. To be able to open DAT video file directly from your Gallery app or MX player, you should rename the file extension from .DAT to .MPG. For example, filename.dat change to filename.mpg. Once you're done, the video will appear on your MX player list and you can now play the video file on your Android device.
Oct 23, 2014 | Samsung Cell Phones
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
How to burn video cd?
Many of these drives came withdriver and video editing software that includes writing the final a dvd. My LG drive came with cyberlink video software. This allows loading video files in many different formats, editing using the included tools to add titles, cut out parts not wanted, setting chapters, then produce by burning to the drive onto a blank dvd disc. Blanks come in dvd-r , dvd+r , and dvd-rw formats. The disc will play on dvd players. When you look at the disc with your computer, all you can see are the marker names. You cannot copy files from video discs. Other video editing software are: Cyberlink, Roxio, Etc... If you need product software, go to the link and enter your drive model number.
Aug 30, 2011 | LG (DRD-8080BB) DVD Drive
I have windows 7 software on a dell computer. Have not been able to open email attachements with extension of DAT or \r\nCOMX. any suggestions?
You should have a software application to read that kind of file in order to read what's really inside on the said file or to view his original image. but you can actually grab and launch it to gnome player or what types of player you have as long as the program inside of it is according to the specified extension file name because for your information DAT stands for Digital Audio Tape or Digital Tape Recorder. NOTE! don't try VLC because it didn't support DAT files.
May 18, 2010 | Dell Computers & Internet
Installation of Oregon Trail 5th edition, stops at 94% c..901.bik an says not responding, then finishes and when you click launch when you exit, it gives can not locate 'oregan5.dat make sure cd is in the...
The file oregon5.dat is installed in the directory "program files(x86)". It can't be found because the computer is looking for it in "program files" WITHOUT "(x86)"! A different directory altogether.
To make it run, cut and paste the sub-directory named "the learning company" into the directory "program files"
I computers!
Nov 08, 2009 | The Learning Company Oregon Trail 5th...
Have a .dat file of office 2007. Need to open it as .PPT file.
In your Windows Explorer Go to
Tools-->Folder Option-->View--> uncheck "Hide Extension fro known File Types"
Now get back to your file.
You'll notice a .dat at the end of the file name. just rename it as .ppt
ex--> filename.dat filename.ppt
Hope It Solved Your Problem
Good Day
Apr 14, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Easy to do.
Connect your mp3 player to your computer.
By default the device is in MPT mode. In this mode you need to use media player or rhapsody or Samsung's own media software to transfer files. You need to have the music on your laptop. Once on the laptop you can edit the details - name, artist, etc to whatever you like. You can then drag it onto the player and it will keep those settings. remember to delete the files with the details you don;t want from the player
Go into my computer you will see yp-k3 device in the listing. You can edit the names directly this way but you cant move them to a folder.
Feb 13, 2008 | Samsung YP-K3 MP3 Player
