Question about SWANN Home Security
My swann 4000 will not startup.tryed ahard start didnt work.
Why does my Swann have no display?
If you checked all cable connections and made sure you monitor is set to the right input and working properly, if the dvr has multiple outputs try them all first. If none of that works it maybe the the video card on your unit is bad and may need replaced. Swann dvrs typically only last a couple years because the are garbage.
Aug 28, 2014 | Swann Communications Home Security
97sebring turns over but won't start
is there a spark as well is there gas no spark no fuel no start oil level prestone level all ok temp sensor corrects timing if not working fuse fuel pump crank sensor does it crank easy with no restriction or does it have ahard time to turn over could be timing belt but first try gas or spark to see if you have them
May 05, 2014 | Cars & Trucks
Manual for swann dvr
Have you tried the swann website..?
try a search for swann manuals too..
Feb 15, 2012 | Swann Communications Home Security
Driver for win 7 64 bit please
Hi jirodia !
Unfortunetly Swann Communications does not provide driver for Windows 7. However, there is a driver for Windows Vista. You can give it a try, as most Vista software will also work on Windows 7. you can download it here:
Best of luck, omerk.
Jan 30, 2011 | Swann Communications DVR-4-Net (SWRPCDVR4)...
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
Swann pro 4000 dvr
Press the “Menu” button and use the Up or Downbutton until “Motion” is highlighted then press the “Enter” button. Use the Up or Down button to highlight the “OFF” next to “MOTION RECORD” and press the + or -button until “ON” is shown. Use theUp or Down button to Highlight the (MENU) then camera you wish to enable, then use the Left or Right button to highlight the “OFF” next to that camera and press the + and - keys to adjust the setting to “ON”. Use the Right key to highlight “AREA” next to the camera you wish to enable, and press the “Enter” button. Press the - button to turn on Motion Detection for the whole screen as shown by a green overlay, then do the same for your other active cameras.
Jan 14, 2009 | Swann Communications DVR4-Pro-Net...
Startup does it have a virus
Can you hear the drive startup? Is the drive present in the BIOS? Press f8 key when rebooting. One of your choices should be disable auto-restart. This will allow the blue screen to stay and you can see what kind of error the machine is giving. Are you pressing f1 to continue with no drive found or drive settings have changed? Assuming your using XP try booting from the CD. Act like your going to do a fresh install. The install should find and existing install. From there select repair. You will have to download all your updates and may need to re-activate XP. But it could get you up and running as long as the the board on the drive isn't fried. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Home Security Logo
44 people viewed this question
Top SWANN Home Security Experts
Todd Arndt
Todd Arndt
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
