Question about Haier Washing Machines
Haier washer rest button - Haier Washing Machines
The "On/Off" button is stuck pushed in and the light stays on. Now the "No Spin" button is stuck in the pushed in position also and I can not dry clothes.
Hi Cindy,
I think that you're going to have to remove the control panel and see if you can get to thebuttons from the back. Make sure that power is off.
Aug 06, 2015 | Haier XQG50-11 Front Load Washer / Dryer
My Haier washer can not rinse and spin
My Haier front loader can not spin out correctly it's to loud and shakes back and forwarder spinning out on the wrong load because the size load button is struck in side the machine and won't pull out.
Sep 29, 2013 | Haier Heating & Cooling
Need a manual for a HDW201SS
follow up link:
Please endorse me if helped :)
Jan 11, 2012 | Haier Dishwashers
I have a Haier XQJ50-31b and the display seems to be stuck, the lights come on but I can't change the programme or make it start
I tried the hairdryer solution, didn't work for me but a hot water bottle on the buttons over night did!
May 12, 2009 | Haier XQJ50-31 Top Load Washer
Haier Microwave, only the #1 and 2 buttons work. None of the rest of the numbers do anything.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Otherwise, you can contact Haier customer service here for more help.
Dec 04, 2008 | Microwave Ovens
Haier Not Drying
most likly to be thermostat if you remove the lid you should see 2 little round thermostats on top somewhere some stats have a reset button on 1 of the thermostats if there is press it if it clicks try it on a dry to see if it works
Sep 21, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Sep 03, 2007 | Haier hwr10xc6 Air Conditioner
Haier washer won't start
1. does machine light up on control board? no. check breaker box or try plugging a lamp into the same outlet to see if it works. for this problem you may need a repair man to look at it.
Mar 21, 2007 | Haier HLP21E Top Load Washer
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
