How to charge a wireless headphone called by-bo-101?
    Master:
  • 507 Answers
Normally those headsets are charged via Micro-USB i would think....im not fully sure unless you have a photo of the headset
Posted on Dec 05, 2016
Transmitter requires dc3v transformer but I don't have one. Can I use a 9v or 12v transformer?
Bo, you will almost certainly destroy it. Radioshack in the US and Maplin in the UK should stock them
Jun 04, 2015 | Sylvania Wireless Headphones With Fm Radio...
The green charging light is not coming on when the headset is placed on the charging station
Wait to see if it gets a charge on the port. If the headphones don't work, call customer service for troubleshooting relief.
Apr 06, 2015 | Thomson WHP3001BK WIRELESS HEADPHONES
Charging problem?
The battery in the headphones is most likely not taking a charge anymore and will need to be replaced with an equal value rechargeable battery
Jan 04, 2014 | TekNmotion Airhead 1000 Wireless...
My ooutdoor tecnology tags are not charging on my mac when I plug in I keep swicthing plug in port . Any Ideas??
How old are they and have you left them on the charger for long periods of time? The batteries are small and dont last long if they are old or constantly over charged.
Sep 09, 2013 | Outdoor Technology Ot Bluetooth Tags...
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
Motorola S9-HD will not turn on or charge
I had this problem as well, and my issue stemmed from a faulty charger that came with my headset. I would suggest trying to charge your headphones with a different cable. I found that I could charge my headphones with the microUSB cable that connects my laptop to my external hard drive.
Jan 20, 2010 | Motorola Mobility MOTOROKR Bluetooth...
FM wireless headphone batteries not charging . Green light does not come on at all. Red light comes on sometimes.
you need to replcae the charging pin of your head phone, it is having loose connection............
Jun 20, 2009 | Philips (33-01-031) Headphones
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
May 01, 2009 | IOGear (GBE201W7) Wireless Headset
Logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Dec 17, 2008 | Logitech FreePulse Wireless Consumer...
52 people viewed this question
 Grubhead
Grubhead
