Could you show me picture of reset button on hazier washing machine
3 Suggested Answers
  • 112 Answers
SOURCE: Hotpoint washing machine HVF 344. When program is
turn off at the wall power switch.....leave off for a few mins then retry.
Posted on Jul 20, 2010
j_smith1234
SOURCE: Hi, How Can I Reset error in my wash machine Bosch
Error code reset on Classixx 6 1200 Express
The post above is correct, just missing one detail, see below;
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position. Wait for Error code to flash
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (Drain position)
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off. Wait 5 seconds
When you turn it back on it should have cleared the error code.
Posted on Dec 13, 2014
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
Nov 17, 2016 | Washing Machines
LG wm2655hva front loader won't stay powered up. Initially showed a PF code, now shows 3 dashes. Power button works for 5 seconds & shuts down machine....
Hey Kemp!
  • Unplug the machine and hold the power button to reset.
  • OR TRY Unplugging the washer for 5 minutes to see if it will reset itself.
  • If NOT, you will have to replace the control board to fix the problem.
Best of Luck!
JP
Jun 08, 2015 | LG Washing Machines
My washer dryer is showing that its still locked after i turn it on and onpen the door
You may have locked the machine by accidentally leaning on the buttons. I can't see a proper clear photo of this machine's control panel, but there may be two buttons on the front of the machine with a picture of a lock underneath them (on mine they are marked 'option' and 'extra rinse'). Hold both in at the same time and this will deactivate the lock.
Feb 11, 2014 | Zanussi ZWF1430W Front Load Washer
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
Lg wd80160fu front loading 7kg washing machine when power is on shows (cl) on its screen.
cl is child lock......look for your units user manual and reset the child lock....usually its one button to push and hold in.....but some lg's have two buttons......just look at your user manual and reset......
a feed back would be good if this helps
thanks
May 16, 2010 | Washing Machines
Reset machine
turn off machine by pressing power button hold down temperature button on front panel turn on machine while still holding temp button in quickly release the temp button and press the soil button. release the soil button and you should see a diagnostic mode on the screen there will be several sets of numbers on the screen the first set are number of wash cycles then the most recent three fault codes indicated with f1 f2 etc the last number is the software version in the computer when you can see this on the screen you will be able to reset the machine simply by turning off the power and then on again the fault code should then be gone
Nov 15, 2009 | Dyson Memory CRO1 Front Load Washer
I have a bosch washing machine. The tumble lights are blinking and I cannot get the machine starting a new program
Restart the machine and repeat the following procedure to reset the machine to original factory settings.
Enter the test program by:
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time.
Post the results.
The result would be a fault code which indicates the error. Will await your further comments.
Apr 10, 2009 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
