Question about Foredom Tools & Hardware - Others
Where can I get a Manuel for a foredom model C202 wood carving tool?
4 Suggested Answers
  • 257 Answers
SOURCE: My ROTO ZIP RZ10 burned out after less than 3
Hi again, I think you will be happy you opted for the warranty solution, I told you they stand behind their products, Thanks for sticking with it and I'm glad we could help Fixya!
Posted on Mar 02, 2009
  • 384 Answers
SOURCE: carving stone with a rotary tool
Are you asking for permission? If so, it OK with us, better check with your wife and her mother.
Posted on Jul 21, 2009
  • 19 Answers
SOURCE: what are the benefits of wood carving
The advantages would be that you can make many nice things, including bird houses and feeders as well as cabinets etc.
Posted on Oct 17, 2012
Do you know the grade of these chisels?
hi Rebecca
if there is no name on them they are more than likely to be cheap Chinese. very low grade
Apr 26, 2014 | td industrial 12 Pc Wood Carving...
Instructions to carve wood with rotary tools
id say your best bet at doing this is find someone experienced with this (ck out your local craft fair) and ask if they would accept you as a apprentce for a time (week,month,year) this could teach you lots
Mar 14, 2014 | Tools & Hardware - Others
What are the benefits of wood carving
Oct 17, 2012 | Audio Players & Recorders
My tool is dead. Is this the sign that the brushes need replacing?
Its may be the brushes just unscrew the brush caps with a dime or screwdriver.
Otherwise check that power to the outlet and the tools power cord has no damage.
Jan 20, 2011 | Foredom Mh 5 Rotary Tool Motor Hanger
Side mini door wont open on my 99 f-150
The plastic ends of the cables that are fixed so the inner cable moves freely to pull the locking mechanism desintegrated causing it to be inoperative. The cables are not sold alone. You have to buy the whole door locking mechanism to fix the problem. However, here is an idea. Take two small pieces of wood and hold them together with a C-clamp. Then take a rotary tool and carve a groove, wider than the cable cover, at the woods' joints to place later the cable end into the groove. Drill a small hole at the wooden side to let the inner cable come through it on the side, while the cable cover sits inside the carved groove. Place a small nail to hold the cable in place. Prior to place the cable in place, take a candle and spread a film of resin inside the carved groove. Put a small amount of grease where the inner cable enters the cable cover to prevent the cables to be glued. Pour epoxy inside the groove with the cable inside as explained. The epoxy must cover the cable. Let it harden. Remove the C-clamp. Using the rotary tool, carve a slot at the epoxy end where the cable comes outside, to place it in its site where the original broken plastic was located to do its job holding the cable. Now the door mechanism will perfectly work without having to buy the whole door lock array. Use West System epoxy. is my email if you want to see photos of the process. It saved $350. bucks for me and the doors are working good.
Mar 01, 2010 | 1999 Ford F150 Regular Cab
Existing doll house has very thin wood.aboyt 0.3mm
in those days they used very soft balsa wood, which was easy to carve. you can still find this at specialty wood shops for carvers etc.
Aug 20, 2009 | Toys
Sanding china edges
Try the 1/2" Drum Sander with 180g-220g Paper(Emery works Best)...You Might Try a Taper Spindle, and Purchase Sanding Rolls to Fit (usually get a Bag of 50 for about $5, Lots easier to change out, plus they come in Various Profiles and Grits.
Someday You might want to Upgrade to Either a Foredom, or a Dumore, You would be a Lot Happier.
I Use a 1/4HP Foredom for Metal Polishing, can't imagine anything else...Have Fun!
Jan 30, 2009 | kawasaki 840168 Green 150 Pc Rotary Tool...
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Die Grinder usage
these tools are handy for any finishing or grinder that needs to be done in a small spot.
Aug 27, 2008 | Taylor Pneumatic: 31 Pcs. Sanding Prep....
Model 680
you can use wood to carve one, it is not too hard especially if you have the right tools. I was also looking for the same parts, and the sliding rail. I did not find it and had to make one with a piece of wood.
Nov 06, 2006 | Kinderkraft Vermont Crib
Tools & Hardware - Others Logo
Top Foredom Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Foredom Tool and Hardware - Other Expert? Answer questions, earn points and help others
