Question about Ovens
How to fix a f222 fault
Forgot to add, it's a Fisher & Paykel. Oven was on at 190c fan forced and had been on for approximately 4 hours. When the fault came upthe oven switched off. We turned it off then on at the meter box and it worked for only a moment then the same thing happened. The modelnumber is ob60sl11depx1 and error f222
textonor
  • 130 Answers
SOURCE: Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Posted on Feb 04, 2008
SOURCE: fan Oven keeps tripping the electric box
keeps triping main fuse box off
Posted on Mar 20, 2010
kojak18
  • 31 Answers
SOURCE: My Fisher & Paykel Paprika oven has
check the ignitor and the oven thermost. the oven control board may be out.
Posted on Jun 22, 2010
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
  • 161 Answers
SOURCE: cannot switch off oven fan.
WARNING
Go back to the switchboard and turn the oven OFF, (Switch the fuse off at the switchboard)
Your Oven sounds like it has shorted out.
DO NOT TOUCH IT
It could be live, Electricity can cause serious injury and even death,
Get a Registered electrician to check this for you. DO NOT use it.
Looks like you might be ordering out for dinner tonight :-)
Take Care
Posted on Feb 09, 2014
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
Fisher and Paykel oven hot heating on fan force
Possibly a burnt out fan element. You or a service person needs to test the element & wiring with a multimeter.
May 10, 2016 | Fisher and Paykel Ovens
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
The lower oven of my Fisher Paykel B1603ED dual oven is oven is overheating. I carefully replaced the Thermostat with a new and it did not fix the problem. Also when it is set to fan forced it will no
The model number supplied cannot be found on the web site a parts manual can be obtained to provide information on your product.
goto fisherpaykel.com and find the manuals available parts would be best and they may use several ways of regulating the supply . Or an element has blown visual check when cooker is ISOLATED FROM THE MAINS SUPPLY. There usually is a Grey colour round the hole in an heating element, if not sometime a black ring as if too much heat in one spot, test with a continuity tester it should have conduction.
Hope this is helpful
Regards
John
Nov 01, 2014 | Ovens
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
hELLO THERE:
Jul 14, 2010 | Fisher and Paykel Ovens
How do i turn on the oven?
First set the clock if you cant do that just press buttons till the numbers stop flashing the turn the knob with pictures to one that looks like a fan in a box that should be fan forced option the select the tempreture with the other knob
hope it helps
Aug 17, 2009 | Fisher and Paykel OB24SDPX1 Electric...
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Feb 03, 2008 | Ovens
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
