Question about Home
My Howard Miller floor clock strikes each hour correctly until 11 or 12 am and pm then it strikes one hour behind. What could cause this?
  • 277 Answers
It sounds like it may have a tooth that is damaged on the counting gear in the strike train. You should take it to a clock repair shop.
UsedClockParts.com
Posted on Dec 08, 2016
My Howard Miller Grandfather floor clock 610-808 chimes constantly
Hello Shirley Haas,
Leave the weight fully extended (stop the clock)
and start checking your local area for clock-smith
that make house calls (run on hour strikes are much more common... but whatever you say... "CHIMES" the cause
is likely the same: Little or no maintenance).
http://www.ebay.com/itm/Howard-Miller-Grandfather-Clock-Movement-with-Dial-Model-610-309-serviced-/282379781809?hash=item41bf2586b1:g:UO4AAOSwMmBVjdo-
These clocks need to be lubed and serviced and it is work
best left to the serious professionals.
You can probably get away with another 35 years...
Remember we have time on our side...
As for me...
I bought a junk clock to EXAMINE & fix (did)
I purchased synthetic clock oil (LIBERTY noted below)
and lubed ALL the obvious spots...
wiping excess away with Q-Tips.
Then I assaulted my own RIDGEWAY...
Got it running & regulated (was NOT my problem)...
My pendulum only needed to be centered correctly
(oh well).
I could NOT pull up YOUR 610-808 movement... but on the movements I have done you can see the hour strikes & the lever that triggers that motion (HOURS are each a spike on
the gear wheel... from one (^), 2 (^^) to 12 (^^^^^^^^^^^^)
progressively (pretty obvious if you are looking).
Go there... look... lube..!! Be gentle... VERY GENTLE...
or better ... call in a QUALIFIED SERVICE PERSON.
Carnac the Magnificent
Mar 24, 2017 | Home
I have an electronic Howard Miller wall clock that chimes but is two hours behind the time showing
Move the hour hand counterclockwise two hours back and then just move the minute hand clockwise until the correct time is set.
UsedClockParts.com
May 28, 2015 | Home
My Howard miller clock chimes one hour ahead . It
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Oct 07, 2014 | Home
Clock is in sync but hour chime only goes to 5 ?
You'd have to take the dial off so you can see what's going on in there. Your movement, (probably a Kieninger) has what's called a rack and snail that determines how many times the clock strikes.
It sounds like either the racks being prevented from falling further than the five position. It may just need to be cleaned, and oiled (with clock oil), or something may be damaged.
It would probably be less hassle if you called a clock shop to service it for you. If It were in front of me I could tell you more.
Good Luck
Sep 19, 2014 | Howard Miller The J. H. Miller I Floor...
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
How to reset clock chimes
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Nov 04, 2013 | Home
What does my Howard Miller Tide Clock need to be set on right now
You need a local tide chart. You can look up online or get a printed on at most tackle stores. Based on high or low tide, turn the knob in the back to match. For instance, if high tide at the location you want to monitor is 12 noon, and is is 10 am, align the hour hand with the "2" to the left side of high tide.
Jun 27, 2012 | Howard Miller Tide Mate III Tide Clock
Chime strike on middle of 1&2, 4&5, 7&8 and 10&11 instead of 3,6,9 and 12.
We understand your question:
The hand has a center bushing with the square hole in it.Remove the hand and use a pair of pliers on the bushing in the minute hand then re-clock or rotate the bushing back on the quarter hour then replaced it back on the clock.
Hope this tip provides some workable ideas for this repair.
R/
David
Orlando
May 19, 2009 | Miller 645-586 Clock Radio
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Apr 05, 2009 | Oregon Scientific Lwb0997110113004...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
