Question about Honda Electrical Supplies
Greetings. I have a eu2000 honda inverter with the following problem. The high generator runs too fast, when the idle is activated, slows down a bit, but does not increase
    Top Expert:
  • Honda Master
  • 49,228 Answers
On the governor control back to the carby , there is a screw that adjusts the spring tension for the governor arm
that screw is the adjustment for engine operating rpm not the idle screw
Posted on Dec 13, 2016
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
Should i use regular gasoline in 2000 watt generator
It is ok to use 87 octane regular unleaded gasoline in a Honda EU2000 generator. I have been running it in mine for 4 years with no problems. Using the higher octane blends is just a waste of cash.
May 22, 2014 | Honda EU2000i1A1 - 2000 Watt Generator
EU6500 eco switch on won't idle down the engine
need more info did you leave gas in the tank without stabil if so carburator is got gas sludge in it
Feb 27, 2014 | Honda EU6500iS Inverter Generator
Honda eb5000 generator
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
Brand new gx390 Black Max generator backfires when shut down. Might this be plug gap problem?
If you can access throttle linkage to the carburetor, slow the engine speed to idle before turning off. As mentioned in the previous answer ... turning off the fuel valve and letting it run dry is good if you are not planning to use it real soon.
Aug 11, 2011 | Honda Electrical Supplies
1986 Honda Accord DX - too high idle on cold start
1986-1989 Honda Accord with Carburetor have a very bad habit that is little known even by most mechanics but easily fixed at home. The vacuum port on the choke opener that is connected to the intake manifold and both vacuum ports on the fast idle unloader get plugged up with nasty hard carbon almost as hard as metal. When this happens the choke sticks closed and the idle sticks on fast idle when the engine is cold and nobody can figure out why. All you have to do is attach a small drill bit to the end of a flexible socket-driver extension and put it in a variable speed drill that will let you run it real slow and carefully drill out the vacuum ports that are plugged. After they are nice and clean use a vacuum pump tester to make sure the choke opener and fast idle unloader are working before putting it all back together. It's amazing how much better the car runs after cleaning out those ports.
Jun 14, 2009 | 1986 Honda Accord
Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
May 28, 2009 | Electrical Supplies
Vn800 running fast on tickover
I am not sure what you mean on the "running fast" statement. If idle speed then turn the idle screw outward to slow down the idle.
The backfire is caused by turning off the ignition key when the bike is at high revs. let it idle down THEN turn it off. The backfire is there because the carb idle circuit is active anytime the piston is in motion. Gas goes into the cylinder as the bike revs down then a hot spot in the exhaust pipe finally ignites the built up gas. There is your backfire.
Is the running fast question answered? Give me more information on the problem if it isn't.
Please rate this answer. Thanks njv6!
Apr 15, 2009 | kawasaki KX 250 Motorcycles
Electrical Supplies Logo
42 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
