Question about Magnavox Televison & Video
Is there a sequence of buttons to push to reset my magnavox zv427mg9? unpluging the unit does not seem to help. I have dvd/vcr and power switch flashing and will not power up
SOURCE: no power in magnavox mwd2205 vcr/dvd unit
how do i hook it up to a tv ?
Posted on Dec 12, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Posted on Dec 20, 2008
ltfrc
  • 227 Answers
SOURCE: Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Posted on Jul 25, 2009
  • 86 Answers
SOURCE: magnavox dvd vcr recorder will not turn on
check fuse inside on board for power u have to take a part
Posted on Oct 08, 2009
We just unplugged our sony dvd player and plugged it back in and it worked.
Posted on Oct 14, 2009
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Does The Magnavox Dvd Recorder / VCR zv427MG9 Have An In Line Fuse
There is a replacable glass cartridge type fuse inside it. It can be located at its mains power supply regulator board.
Jun 09, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Magnavox DVD recorder VCR DVD will not open
Unplug player for 2 minutes, now press and hold power for 30 seconds and release, plug back in and try again, if no! it must be dismantled to recover the disc.
Apr 04, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have a Magnavox DVD Recorder/VCR ZV427MG9, but I don't have an instruction manual to go with it, at least on how to record from VHS to a DVD, could you tell me where, via internet I would be able to get...
You can probably download the pdf of the manual for this model from the following site:
http://tv.manualsonline.com/manuals/mfg/magnavox/zv427mg9.html
The document should feature a picture of the unit. This is for the ZV427MG9 model ONLY.
I hope this helps somewhat.
Mar 15, 2011 | Philips DVDR90 DVD Recorder / VCR Combo
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Magnavox DVD VCR recorder ZV427MG9 A:I can get the
I can't get the player to switch to dvd so I can eject the dvd disc
Oct 19, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Is there a remote control code for model zv427mg9?
For my direct tv remote, 20675 worked for me :) magnavox zv427mg9 combo vcr, dvd
Sep 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox dvd/vcr dual player wont work with satellite! HELP
please check if have any light indicators working, if nothing. check the fuse first from primary ac. be sure cable is unplugged.
Aug 20, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Televison & Video Logo
53 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
