Question about Vacuums
Cordless vac sucked up a little water and now will not run - any fix available or did I ruin it
4 Suggested Answers
  • 120 Answers
SOURCE: vac not sucking up water
its supposed to, it means you need to dump out the tank. Its a safety feature that keeps the water out of the motor. if its lifting up due to foaming, than try using the original brand shampoo
Posted on Jul 13, 2009
SOURCE: Steam vac is not sucking up moisture like it
Check hoses for possible leaks.
Posted on Nov 21, 2009
VacuumRepair
  • 438 Answers
SOURCE: My steam vac stopped sucking up the water. How do
Hi There,
Here's a link to the instruction manual for your Hoover SteamVac. There is a trouble shooting guide in the back of the book that will explain how to check no suction problem.
If none of these suggestions fixes your machine, please just refer to my answer below the link, these are the problems you may have.
Here's the link:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture2_bing.gif and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
Posted on Apr 23, 2010
It wont suck the water back up
You are not suppose to suck water with an ordinary vacuum. If its a shop vac yes. Otherwise you will ruin it.
Jan 06, 2017 | Vacuums
Dyson V6 Animal cordless does not suck very well. No blockage of any kind, and all filters have been cleaned.
Battery not fully charged possibly needs replacing. If a battery is not fully charged it will run only half speed with no suction.
Dec 01, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Is not sucking. Water comes out fine, but when the trigger is released, the water does not get sucked back.
Without more input from you, it is difficult to know what the problem is. Do you hear the vac motor wining ? If so, then ther is a clog in the passage or there is damage to the vac motor/impellor blade. If no sound from vac motor, well of course it will never ****-up the water. YOU WILL NEED TO TAKE IT TO A GOOD HANDY MAN OR AN APPLIANCE REPAIR/VAC REPAIR CENTER. Good luck, Macgivor
Oct 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
had my steamvac spinscrub for 3 days now. it will not **** up why?
Jan 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Shop Vac Model 758.17871
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
