Question about Keurig Coffee Makers & Espresso Machines
My keurig turns on it says not ready and then it shuts off, why?
Barely used keurig and when I turn it on it says not ready and then after a minute shuts off. I dont think the water is getting heated at all...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 31, 2011 | Keurig B60 Coffee Maker
Coffee maker turns on says "not ready" and shuts down 3-4 minutes later before it ever gets ready.
heatman101;';
Aug 31, 2011 | Keurig B70 Coffee Maker
When I turn on my Keurig machine, it says "not
Don't put a new coffee pod into it until the machine says ready. If you already have, just open and close it again.
Jan 27, 2011 | Keurig B100 Coffee Maker
Machine shuts off and says NOT READY. It will not work again until it is unplugged for a minute. Plug it back in, water heats and READY. It is not set to shut off. It shuts off soon after using for no...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dad
asd
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
Never gets ready, keeps shutting off.
Try using a straw. Use it to blow thru the hole where the reservoir attaches. I tried this on my B40 and worked.
Feb 23, 2010 | Keurig B70 Coffee Maker
Keurig turns off after making only one cup, when turned bsck on, it makes a loud buzzing sound for a few minutes, then shuts off again (during this buzzing, always says "not ready", never gets back to...
I just solved this problem with my Keurig Plantnum. It seems that the valve that lets the water in is sensitive to clogs or sticking. Or perhaps like me, you have very hard water and calcium is starting to build up. Anyway, what worked for me was filling the resevoire all the way and turning the unit on. Then while the pump was buzzing I lightly jiggled the reseviore and all of the sudden the water level started to go down.
Jan 23, 2010 | Keurig Coffee Makers & Espresso Machines
My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Dec 13, 2009 | Keurig B100 Coffee Maker
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
