Question about The Toys
My helicopter t6 wont start only thing come on is the remote control
3 Suggested Answers
SOURCE: New 27 MHZ Helicopter Controller won't turn on
I have a 27Mhz helicoper (looks identical to the one on the picture). I tried to fly it for the first time, but I am having problems controlling it. The left radio control lever sends the helicopter upwards, but the right hand control doesn't seem to do anything and that should make it go backwards and forwards. Can anyone help me as well please?
Posted on Feb 22, 2010
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Syma S033G Helicopter does not lift off then stops
too much power,get a 7.4 volt battery and charge it to 7.4 volts,any more kills battery
Apr 16, 2015 | Syma S033G REMOTE CONTROLLED 3.5 CHANNELS...
Why is that not working?
The antenna in the helicopter might be broken
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
I bought a World Tech Toys ZX-A68690 helicopter and I cant get it to work. I charged the battery pack as outlined in the operation manual. I installed the "AA" Duracel batteries in the...
Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
Turn on the helicopter and you should be OK
Jun 01, 2011 | Worldtech Devices Toys
I bought rc helicopter of alloy king and i dont know how to make it start.
Insert the batteries into the battery slots in both the controller and the helicopter.now you will be able to control the rc helicopter whenever you want by just switching on the remote control for the device.
May 10, 2011 | Toys
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
I have a problem that seems to be in the remote charger. The green light will not come on anymore. the top rotor will not engage. Is this a charging problem in the remote or is it in the helicopter motor?
same thing happened to another person. you need to probably change battery in controller or replace LED, and for the helicopter check for wires that came loose and if so you need to take it apart and sodder it back into place.
Dec 26, 2010 | SYMA Toys industrial New Syma S107 Radio...
Helicopter is unbalanced
Hi. This is called "talk" its when the helicopter starts spinning instead of the blades, remote control helicopters and real ones.To stop this from happening you need to make sure the tail Rotor is going correctly OR probely the best thing to do would be take it back to the shop and get a hole new one.
Aug 15, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
Mar 05, 2009 | Back To Basics Toys R/C Helicopter (27...
Shuttle 9094 r/c helicopter spinning on take-off
usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Dec 22, 2008 | Shuttle 9094 Emax Remote Control...
Toys Logo
29 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
