Pj502. Showing for 4 munit and power off and have to water for 7 munit for turn it on back
Diesel. Reduce power lite turned on. Shut off engine and started back up - lite is off. Can it be driven?
Jerry, Drive to a good shop. So many things can cause reduced power light unfortunately. The first step would be to get the truck hooked up to a scanner/computer and have the computer scanned for trouble codes. One thing that you could try is to drain the water from the water separator that is mounted on the frame under drivers front door. If the PCM picks up on water, power is reduced until water is removed/drained. It could be an exhaust sensor that is reading faulty. Unfortunately from here its impossible to tell you exactly what the fault is because there are just so many engine sensor inputs that could cause your problem. Check the attached links, forums,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reduced Engine Power Light Wrench Showing Ford Powerstroke Diesel Forum
08 Reduced Engine Power
Regen Reduced Engine Power Light Ford Truck Enthusiasts Forums
Help reduced engine power light comes on
Dec 29, 2015 | 2008 Ford F-250 Super Duty
I can't load projector to MacBook Air
some of these new computers wont recognize the older stuff..may need to see about any updates to that video unit that the original program does not have..also look at the instructiuons as a lot of macs arent compatable with that kind of stuff..it should say on the box or owners manual.. if not call the tv manufacturer..
Feb 02, 2014 | ViewSonic PJ502 Multimedia Projector
Why does my tablet keep showing 'data connectivity
this problem allways shown when your tablet have lots cache file so plz update you tab or give small reset soft reset its totally easy just off your tab press down vol button and press home button and press power button after few secound you saw one blue screen shown and some option came 1<formet<2hdd recomded so plz press 1 when you press one you see you tab take some time and you seem few munite latter reboot it and your problem solved
May 16, 2012 | Tablets & eReaders
What is F21. Its keep showing.
Most likely bad water level switch.
Also,
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Washer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 26, 2011 | Kenmore HE2 Plus Front Load Washer
My refrigerator shows an ice make but i can not find the connections to it
THE CONNECTIONS ARE BEHIND THE UNIT TURN IT AROUND AND YOU CAN SEE THE WATER HOSE CONNECTORS, YOU HAVE TO DO SOME WATER INSTALATION FROM AWATER SUPPLY THE MOST COMMON IS THE ONE BY THE KITCHEN/SINK. WHAT YOU NEED IS: A SET OF A COPER TUBE INCLUDE ONE SMALL REFRIDG WATER VALVE. MAKE SURE YOU LET ALL THE AIR OUT FROM THE WATER LINE BY KEEP THE WATER RUN THROUGH THE LINE FOR ABOUT 1 OR 2 MUNITS. AND PUTT EVERYTHING BACK TOGETHER
Oct 24, 2010 | LG LFC21760 Bottom Freezer French Door...
Not really a problem, Ijust want to know how long a normal cycle should last.
wash cycle is between 10-14 munites. rinse cycle is about 10 munites. pluse time to fill and discharge water from the tub. total time should be about 40-45 munites
Apr 22, 2009 | LG LDF6920 24 in. Built-in Dishwasher
TOSHIBA A125 LAPTOP POWER STUCK UP
hi venji,
you question was still not clear. If I'm not wrong you mean to say after 20 mins your computer screen when black and you could not see anything, right ???
did you try to touch the power buttton to turn it on again maybe its in sleep mode.
Or you mean after 20 min..laptop still work but you hardly can see due to no light (back light )??
so I'm not really sure ..please give us more detail.
takecare.
May 29, 2008 | Computers & Internet
Cant Display unless I give it 30 munites.
Connect an external monitor, to initially see if it's related to your screen or the inbuilt video card. There will be a key combination on the keyboard to activate the external monitor. Pls report the results here. And whats "Hello Great house"??
May 04, 2008 | Toshiba Satellite Pro 470CDT Notebook
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
