Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Water Filter Freezes
Refrigerator: GE PS123SGNA BS, Ser. #454828
Water filter has frozen on two occassions. Filter cracks and then leaks water.
  • tfomak Jul 20, 2009
    why would the filter build up excess water?
    Isn't it always full of water when in servive?
    Why will the filter freeze when it is in the refer section that is always above 32 deg. F.?
  • Anonymous Mar 13, 2014
    water line freezes
  • 158 Answers
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Posted on Jul 20, 2009
GE Water Dispenser not working
Sounds like the water tank in the fridge section froze and split open causing a leak. Plus, the water feed line to the dispenser has frozen where it runs up through the freezer door- guessing your trimmer line only goes about 5" into the tube?
There is a water line heater kit that GE makes : Refrigerator Heating Element WR49X10173 .
Then, buy two quick disconnects 5/16" and about 10 feet of 5/16" plastic tubing- use the tubing and disconnects to replace the cracked water tank and you should be good to go... Refrigerator Water Line 5210JA3004K
Jul 03, 2016 | GE Refrigerators
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
Mar 17, 2016 | Whirlpool WRF989SDAM 29 cu. ft. French...
HOW TO CHANGE refrigerator GE ARCTIC PS123SGNA water filter
Filter should be in the fresh food section top right back corner. It unscrews to the left about a 1/4 to 1/2 turn and pulls down. Reverse procedure to install. Not hard at all.
Apr 06, 2015 | GE Refrigerators
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
May 05, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ge water filter cracks
The issue is with length of the filter and the space behind the filter allowing it to bend.
Along with many people we put a lot of things in our frig. When you jam things into your frig they can hit the filter causing it to bend towards the back of the frig. The long filter becomes a lever putting extra force on the plastic threads on the filter causing them to crack and leak.
Luckly we noticed our leak early and did not have a big leak into the floor below. But when I was removing items from the frig to get to the filter we had just bought two big gallons of milk and one was jammed into the filter.
You can try to remember to not put to much on that side, but within a month you will for get. Best thing to do until GE comes up with a better filter is to tape a wedge to the filter that fills the space between the filter and the back of the frig. That way if you jam a big gallon milk into the filter it will not bend and crack.
Jan 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
736 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
