Question about Coleman Heating & Cooling
I need a manual and wiring diagram for a Coleman electric furnace, model3118B750
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
  • 96 Answers
SOURCE: need help hooking the right colored prong wires onto my sequencer
There should be a wire diagram on the back side of the panel you took off to get to the sequencer
Posted on Nov 13, 2008
tborn6
  • 700 Answers
SOURCE: Need wiring diagram
here would be the hook ups that are needed. at the air handler
r-red
g-green
c-common
w1/w2/aux-white (DEPENDS ON WHAT TYPE OF SYSTEM YOIU HAVE)
then these are what goes to the outside unit
y-ylw
o- org/or b-blue
c-white
r-red
personally contact me if yopu still have questions. thanks
Posted on Jan 12, 2009
  • 8 Answers
SOURCE: wiring from thermostat to furnace
Typically you normally will have five wires controlling your furnace and airconditioning. R Y W G C. If you get some thermostat wire. Connect them like this---- red wire will go to R(this is your 24V to thermostat)----yellow wire will go Y(Y is your cooling)----white wire will go W(W is for heating)---green wire to G(green is your fan)---black can go to C(this is your common to supply 24Vto thermostat)
Posted on Jan 19, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman furnace bgm10016ax 4 blinks
Usually on a metal panel you have to remove to access the board there is an electrical diagram. On the side of that is usually a description of what specific blinking codes mean.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Wiring diagram for gas furnace COLEMAN
Alvaro, can you give me the model number of the Coleman Furnace you are needing this diagram for?
Dec 20, 2013 | Cars & Trucks
Hook ignition wire
This is a typical 5 wire setup. The colors can change depending on the person installing the system, meaning if the installer liked using BLUE for cooling instead of YELLOW, that's how he hooked them up. If YELLOW wasn't available, they could of used BLUE or BLACK, and visa-versa. But, the wiring below is the most common. If you have a heat pump system, it will be slightly different. Hope this helps!
R- Red- Power 24v
G- Green- Fan
W- White- Heat
Y- Yellow- Cooling
C- Blue- Common
Dec 07, 2013 | Coleman Heating & Cooling
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
Need wiring diagram ,colman central electric furnace 3500a816
I have the diagram pasted to the cover over the sequencer. I only have a 5 megapixel camera, but I am willing to try and get a picture of it if it will help.
Nov 03, 2010 | Coleman Heating & Cooling
My furnace Coleman DGAT070BDD light flashes 4 times. Do you have any idea what causes that?
Trying to find out what 4 flashes on the internet will be exhausting. However if you have the manual it is explained under trouble shooting. If not, look for a wiring diagram and an error code chart will be on the diagram. Sorry I could not be more help.
Dec 15, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
