Question about Kitchen Ranges
Need to fix my range - Kitchen Ranges
  • 110 Answers
OK, tell us what the trouble - ok? Are the fuse box fuses tripped that feed them 220voits? Flip and reset them - there will be 2 as a set usually, and showing the number 40 or higher number. Flip and reset means to move them to the off position and push them hard - which resets them to flow electricity again - when you flip them back to the on position. This is so if an electric range. Is it electric or gas?
Posted on Dec 05, 2016
Error code sf
sf is sabbath feature. you need to programma per user manua
Sep 19, 2014 | Electrolux EW30ES65GS 30" Slide-in...
Kenmore drop-in electric range plug melted
Hello- Yes it can be fixed- first, make sure outlet is not damaged. If it is, it will need to be replaced. Next, plug is wired into a terminal block on back of unit. With care, this cord is easy to replace. And safer than it was before. A loose plug, or wire caused the fireworks. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 03, 2010 | Kenmore 45062 / 45069 Electric Kitchen...
Ge range js968 f0 error code
F0 error code is a failed thermistor control. The suggested fix is to replace the ERC(electric range control). You will need to inspect the ERC, touch panel, ect for any loose connections that could be causing a short. You can also try unplugging the range for 15 minutes or so and see if the error code clears. If not the ERC may need replacement.
Jan 15, 2010 | GE Profile JS968 Electric Kitchen Range
My ge profile range top and burner work bu the
try cleaning the ignition wire (spark) it works with ground
Nov 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
GR448LXPS electric whirlpool range got the error code E1 F1
This Is what the E1-F1 means and what you need to do to fix.
Safety flip flop Replace Electronic Range Control/Clock (ERC)
Feb 25, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Kitchaid Gas range
heres the thermal fuses thats gone bad its mounted on the back wall of the unit youll need to get behind and remove the panel , unless of course its under 1 yr old then its a warr. issue part#8300802 - THRMST-FIX
Oct 25, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Sep 24, 2008 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
