Question about Microwave Ovens
Microwave started to turn on by itself. Read out said service may be necessary. Then it just stopped working....no lights, no buttons, no electricity.
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Light won't turn off, microwave won't work
the door switch is likely stuck open.
Posted on May 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My kenmore microwave automatically starts and can not be stopped
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
You can find handy exploded views and get part numbers by entering your full model number at the Sears Parts Site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Once you have the Sears part number, you can usually get parts cheaper here.
If you might be interested in having us so the work for you, we charge $39.95.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 10, 2009
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
Posted on Nov 01, 2010
SOURCE: My microwave is 4 years old. It stopped heating
the problem is the diode connected between the chassis and high voltage capacitor. before checking, you must discharge the capacitor by shorting the lead by screwdriver then test the diode by ohmmeter.
Posted on Jul 02, 2012
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Sharp 2010 turns itself on, fan runs but does not microwave
The repair or replace decision depends to some extent upon age and repair history.
Oct 04, 2017 | Sharp R-1210 Microwave Oven
My ge profile microwave oven sometimes turns on when door is clos
hi and wellcome to FixYa this is a comon problem with the control unit for the microwave being damaged the buttons start to stop working more or few buttons at a time, there are companys that sell the front units seperate for these microwaves but can cost more than a new microwave itself , the unit itself is damaged by heat from the microwave or on rare accasions damp im sorry there is no other way to sort this apart from a new front control unit or a new microwave
Thanks Hope this helps a little
Feb 06, 2009 | Whirlpool MH7140XF Microwave Oven
Turns On by itself
Replace it. I work in sales for Whirlpool. It sounds like the door switch is either sticking or shorted. Also because your turntable continues to run it sounds like a short. Microwaves are a unit we only recommend an authorized technician to work on due to the microwaves it uses.
The cost of a new one is usually easily half or more the cost of repairing it.
Average service call just to give you an estimate is 80-90$
Jan 13, 2009 | Microwave Ovens
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
May 30, 2008 | Sanyo EM-S8000 Microwave Oven
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
Starting by itself
Time for a service call. Should not turn on by itself at any cause. Circuit board is my guess. May be cheaper/easier to get new microwave. My first one lasted about 15 yrs--and the circuit board (touchpad) died. Bought new microwave oven.
Dec 12, 2005 | Emerson MW8775W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
