Question about Sharp AL 1631 Copier
My Sharp AL-1631 copier misfeeds in the fusing area by getting stuck right past the roller where the shiny steel tabs should guide the copy back into the machine. This results in making fans of the copy. what are some possible remedies.
  • 32 Answers
Check the separator pawls if they are still in there in the fuser assy. They might have been dislodged when you had a paper jam...
Posted on Jul 23, 2009
You need 1, or both of your fuser rollers replaced.
Posted on Jul 20, 2009
I have a sharp al-1631 copier. it was working fine and then i had a bad misfeed. the paper was crinkled like an accordion, but i managed to get it out of the fusing and area and below the fusing area. ...
You can not make any copies? Is this because it continues to jam every copy in the same location? At the fuser? If so then this means you have a quite common issue with this series of machine. You have a broken fuser drive gear. Part number NGERH0540FCZZ. I have included a picture of the part. All you will need is someone to remove the fusing unit (the part that gets hot) and replace the gear. You can get the part from PrecisionRoller.com
Good Luck and Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Oct 05, 2010 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
WE have a Sharp Al 1631 that the copy scanner won't go the full length of the document
all sharp 1631 models have this problem service scan unit guides and movement placies
Feb 24, 2010 | Sharp AL 1631 Copier
When copying from the SPF the paper misfeeds. It starts through but the goes crooked.
You need to adjust the SPF paper size knob to fit your size of paper freely. Make sure that area is clean or you can wipe with a clean damp cloth the picking roller which is located there.
Dec 23, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
FEED ROLLER Sharp AL-1631
Percision roller phx arizona also have web sight
Dec 26, 2008 | Sharp AL 1631 Copier
Sharp al-1631
there is some paper path sensor in your machine first you should check the area where misfeed light is coming then check the sensor of that area
Sep 28, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
