Question about Radio Communications
I have 2 VISAR HANDIE-TALKIE FM RADIOS MODEL: HD5RDD9AA4AN + DON'T KNOW HOW TO PROGRAM THEM TO THE SAME CHANNELS
    Sergeant:
  • 192 Answers
This is a discontinued radio from Motorola. programming requires a cable to connect to a computer, there is no direct programming available.
While this is not really an answer, the programming software is specific to Motorola and you need to buy both the software and the cables from Motorola.
you would be better served, to determine what frequencies you want and then pay a certified Motorola dealer who has the software to do the work for you.
Posted on Dec 08, 2016
3 Suggested Answers
  • 3 Answers
SOURCE: Can't change channel of a Motorola Visar
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Posted on Mar 29, 2010
  • 24 Answers
SOURCE: need to dis-assemble a Motorola Visar handie
The radio is easy to disassemble and has no hidden surprises, but I doubt you're going to like what you see once you get it apart. The large screws that are very visible on the outside hold both halves of the outside to the thick radio chasey and mother board.
Your volume problem is typical for older T6400s, and is caused by the speaker binding internally. Motorola does not sell the speaker separately and it is built into the case so you can't really just un-hook it and install a new one in it's place.
That's a shame, they are great radios.
Posted on Mar 31, 2010
Testimonial: "Thanks"
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
I NEED SOFTWARE FOR PROGRAMMING MOTOROLLA UHF FM TRANSCEIVER T5930
There are a select number of preprogrammed channels available in the T5930. The programming cannot be changed by software. Sorry. Here is a link to the manual http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf Programming instructions begin on page 18.
Best regards.
Oct 12, 2010 | Motorola Walkie Talkie 2-Way Radio
Need to dis-assemble a Motorola Visar handie talkie fm radio. Radio has intermittent volume, lose connection
Mar 30, 2010 | Motorola Talkabout T6400 (22 Channels)...
Can't change channel of a Motorola Visar Handie-Talkie FM Radio Model: H05RDD9AA4DN It seems that this radio operates in only one channel and I need to be able to chanmge channels. However everything else...
Sep 17, 2009 | Motorola Radio Communications
Info on user manual
Here is the link you need: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
You will find the explanation for programming the radio in the manual.
Aug 07, 2009 | Motorola RDV2080d Two Way Radio
I just got 2 Motorola Visar and i'm looking for an owner's manual to learn using them. Can you help me?
The radios have to be programmed by a RSS (Radio Service Software) and a RIB (Radio Interface Box) is needed. You can learn more about hat by going to www.batlabs.com additionally, the VISAR page is http://www.batlabs.com/visar.html
If you want to buy a RIB you can get the software and programming info at http://www.ham.dmz.ro/motorola/visar.php
Mar 21, 2009 | Motorola iTECH iQfive iQplus -VISAR...
I have a MTX8000 Handie-Talkie FM Radio It is a 16 channel radio
You're on scan mode but have no channel in scan list. You might have to go to scan PROGRAM mode and select the channel you want to scan then press a side button to put that channel in the scan list then will scan.
radcom907
Mar 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Does not receive FM signals anymore, just noise.
The T6310 is a disposable radio. Assuming the programming is correct, and matching on each of your radios, and you are using good batteries, there is nothing which can be done to correct the problem. We would however, suggest you double check your programming, and also the age of your batteries.
Sidenote: Rechargeable batteries only last 18-24 months before they begin to fail. Signs of failure can include, but are not limited to, poor transmit, intermittent transmit, white noise, squelching sounds. It takes more energy to transmit than to receive, so your transmit would be the first to go.
Nov 20, 2008 | Motorola Walkie Talkies 2-Way Radio
Operation of handie talkie GP338
Mostly of this features need to be able by the programing software, this mean that if you dont find it with your menu botton, mean that the radio has disable this features, also depends on the system that provide the service to have this features working, on your profile as customer, ETC Check this link can help you http://www.motorola.com/governmentandenterprise/id_2011i/en-sg/public/functions/browseproduct/productdetailpage.aspx?navigationpath=id_801i/id_1388i/id_1152i/id_188i/id_1363i
Aug 25, 2007 | Motorola Walkie Talkie 2-Way Radio
PROGRAMMING
here is a link to the manual for your radio (english http://myweb.accessus.net/~090/bearcatting.html#motoman They do not give out the information of how to program it, only authorised technicians are permitted to do so. Here is the link to motorola customer support in Puerto Rico https://www.motorola.com/pr/feedback.jsp They should be able to tell you where you can get your radio programmed, and what programming is permitted in PR. Hope this helps :)
Mar 21, 2007 | Motorola For MT1000 MTX800 MTX90010v...
Radio Communications Logo
587 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
