Question about Garmin GPS
I have Garmin 541s marine gps. Low light is locked.cannot see screen in daylight. How can I correct this problem? Thanks, perry
SOURCE: LCD Screen Faded Out
saw this on a different forum.
I apologize for the inconvenience. After further research with our engineers, a problem has been discovered on your C550. A file has been created to stop the unit from turning off and locking up. Please download the new file from your computer to the unit. The file is attached to this email along with instructions on how to get the file into the unit.
The following procedure will update the software in your C550 series and correct the power issue you are experiencing with your Garmin C550 series
1.) Let the Garmin sit without power for at least 24-48 hours.
2.) Plug the C5xx series into the your computer (using a USB port in the back of the computer) with the cable provided with the unit.
3.) After removing the faceplate on the front of the Garmin press and release the reset button. At this time the C550 series will reset and power on.
4.) Save the attached file included in e-mail from Garmin Product Support. Save this file to the desk top on your computer. Note: This will make it easy to find.
5.) Open the My Computer window (by accessing the start menu on the bottom left of your computer screen).
6.) Locate and open the Garmin Mass Storage device.
7.) Locate the Garmin folder and open.
8.) Open the remoteSW folder.
9.) Copy the file that you have saved to the desktop and paste it into the remoteSW folder you have just opened. Make sure that none of the files contained within the remoteSW folder is highlighted, or you will not be able to save the new file.
10.) A message window will pop up asking you to confirm that you want to replace the file; Select Yes.
11.) Disconnect the C550 series from the USB cable and let the unit restart. A message will appear on the screen stating "Updating PLD Software".
Note: the screen will fade out and go blank during this process. Do not be alarmed, this is part of the update procedure, and the screen will return to normal within seconds.
Posted on Dec 26, 2007
SOURCE: Garmin GPS touchscreen is damaged - what can I do?
Overlay is dented.
Posted on Sep 13, 2008
sharcnet
  • 2130 Answers
SOURCE: Purchased used Garmin nuvi 205w/
Please click on this link to download the manual.
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
If you have any further questions. I'll be more than happy to assist you.
- Jim
SHARCNET-USA
Posted on Feb 16, 2009
dirinda89
  • 214 Answers
SOURCE: i want a manual for a gaarmin summit gps marine
Here's a link for your manual. I checked it. If this helps you plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://www.geog.leeds.ac.uk/support/labs/GPS%20-%20eTrex%20Summit.pdf
Posted on Feb 27, 2009
  • 59 Answers
SOURCE: can the Garmin 126 Marine GPS be hooked into a VHF radio emergenc
The comprehensive PDF on the Garmin site here:
http://www8.garmin.com/support/faqs/faq.jsp?faq=68
may help.
Posted on Sep 04, 2009
Garmin 541s transucer, unit problems
Sound like the transducer is catching air.
May 10, 2013 | Garmin GPSMAP 541s
Garmin 541s rear tansducer does not read after plaining out
first of all it wont read after you plain out and as far as cutting off connect it straight to the battery see if that fix your problem
May 08, 2013 | Garmin GPSMAP 541s
I lose depth when moving
that's common with all depth finders when on plane you loose bottom lock when you slow down to stop does it start to work again if so you have no problem
Apr 22, 2013 | Garmin GPSMAP 541s
Hi, I have a garmin Nuvi 700 series.I was uploading new maps when the computer battery died during the process. I tried to re-load the maps again, but now the computer doesn't even acknowledge that the...
try a reset by turning the power key to the left and hold it for 8 seconds. Then turn the Nuvi back on. It should work then.I have attached a link to the owners manual for your Nuvi.
Thanks for using FixYa
http://www.gawisp.com/perry/nuvi/nuvi700-GPS-Atl_OwnersManual.pdf
Apr 11, 2011 | Garmin NUVI 710 Car GPS Receiver
Hi the screen on my 176c is so dark it can barely be read. I have to turn the light on to see whats going on.Is there any way to restore it to its former glory cheers ......john wainwright. ...
John, the light sensitive IC has failed. This is a small piece of electronic wizardry that adjusts the brightnessdepending on the ambient light. At night is is supposed to add brightnes and in sunlight reduce it
The sign of failure may have been early but you didint notice it. They often turn on ok then suddenly in daylight the screen will darken, turning the unit off and on resets it for a while. however it gets worse as time goes on.. iT is not a DIY and has to be sent back to the manufacturer for correction.
Contact Garmin for a quote before submitting it for repair, you might need a chair to sit on when they give you an answer. Contact the service support in 7 hills NSW 1 800 235 822
Please rate my help++++ Thanks forf using FIXYA
Aug 04, 2010 | Garmin GPSMAP 176C GPS Receiver
WE HAVE PURCHASED A ETREX GARMIN BLUE IN COLOR AND ARE WANTING TO KNOW HOW TO GET DOWN LOADS FOR MARINE WITH OUT PAYING FOR THE CD OR DOWNLOAD
You need Garmin MapSource (Trip and Waypoint Manager) and a data cable. Then for free maps visit the murky internet sites and beware of what you download. I would not bother with a topo or marine maps on a grey screen GPS anyway as the colour maps will not be easily understood on a grey screen.
Aug 28, 2009 | Garmin eTrex Legend GPS Receiver
While on a road trip my 60csx quit acquiring satellites.
Try downloading and installing V3.70 from here http://www.gpsinformation.org/perry/gps60/
make sure you use the right one for your GPS
Jul 03, 2009 | Garmin GPSMAP 60CSx GPS Receiver
On the GPS Garmin the radar screen shows our boat turned the wrong way. How do you turn the boat around on screen?
My husband moved the boat slightly and it seemed to correct the radar screen somewhat. He is working on the whole boat at present so didn't want to take it completely for a drive down the river. If we have further problems we may call in or use the web site.
Thanks,
Farrar
Jun 23, 2009 | Garmin Gpsmap 4208 Network Bundle
Compatable marine maps Australia for garmin etrex legend
You can purchase the Bluechart Marine maps for your area online at Garmin.com. They will sell you an unlock code for a specific area.
Dec 27, 2008 | Garmin eTrex Legend GPS Receiver
Garmin nuvi 350 time change
Garmin released firmware version 4.40 to correct DST (daylight saving time in the United States) If your device firmware is 4.40 or later then it should correct once you turn the unit on it acquire a satellite lock.
If your unit firmware is earlier than 4.40 then you will have to update to the latest firmware from garmin site.
If you don't want to upgrade then reset your timezone to one that is an hour earlier. Or wait until April and it will change time by itself.
Mar 10, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
