Question about Cell Phones
CAN NOT ANSWER PHONE - Cell Phones
Why am I unable to answer my phone?
Unable to answer calls - Support forum
https://talk.sonymobile.com/.../Unable-to-answer.../839311
Sony Mobile
Solved: Hi, my Z3 compact has been working fine but this evening I suddenly ... Thephone rings out but the swipe icons for answering the call simply don't ...
Unable to answer phone - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Droid Incredible
Oct 24, 2010 - 8 posts - ‎6 authors
I am unable to slide the "answer bar" across the screen, to. ... I'm trying to determine if this is a hardware problem with my phone of if it is a ... Why am I unable to answer calls on my Galaxy Exhibit ...
Mar 30, 2015
Can't answer incoming calls...
Jul 24, 2014
Galaxy S5: Slide to answer problem
May 11, 2014
Cannot answer phone calls
Mar 7, 2013
More results from forums.androidcentral.com
Jan 01, 2016 | Cell Phones
How to answer an incoming call
blu Cell Phone Product Support ' ManualsOnline.com
www.manualsonline.com/support/blu/cell-phone/
how to answer incoming call? blu Cell Phone ... Please help find the manual for this blu Cell Phone. blu Cell ... i have a blu advance phone and when i turn it on i.
How to answer an incoming call - Fixya
www.fixya.com/support/t25919932-answer_incoming_call
Oct 22, 2015 - how to answer an incoming call - Blu Advance 4.0 L 4G with 4GB question. ... My BLU cell phone is stuck on the boot screen how do I fix it?
Can't answer incoming calls... - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Samsung Galaxy S5
Jul 25, 2014 - 18 posts - ‎12 authors
I did see a similar post but the other guy's phone was a Nexus 5. ... Big big battery ... 1 or 2 out of 10 incoming calls, I am UNABLE to answer, the swiping .... I called my provider (Rogers), had them do an 'advance exchange' ... I can't hear anything when making a phone call, but ...
Oct 17, 2014
Call forwarding or rather how to undo it
Sep 19, 2013
Auto Answer on my S3.....Please help?
Aug 18, 2012
Assigning ringtone to a contact - help please
Sep 2, 2011
Oct 22, 2015 | Blu Advance 4.0 L 4G with 4GB Memory Cell...
Phone doesn't answer when flipped open
Hi
The phone did not answer when flip up because you did not activate it.
To activate go to call, go to answer by flip and click yes.
Any time a call come in and you flip it will answer.
Aug 18, 2010 | Motorola Mobility W385 Cellular Phone
My samsung tocco lite only rings 4 times and then goes to answer phone how do i solve this problem?
Your phone has been set to Auto Answer, to disable this, go to Call Settings and Select Answer mode and uncheck/disable the Auto Answer. Good luck.
May 18, 2010 | Samsung SYNC SGH-A707 Cellular Phone
KX-T7730 Corded Phone: WHEN THERE IS AN INTERNAL INTERCOM ACTIVATED TO AN...
Make sure the Auto Answer button is not lit on the empty desk phone, then you could use either 40 to answer all calls, or 4+ the extension number to absolutely answer that phone.
May 06, 2010 | Panasonic KX-T7730 Corded Phone
Answering the phone
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 to answer external incommincg calls. To answer extension phone press 4 followed by the extension number.
Thank you
Nov 19, 2009 | Panasonic KX-T7730 Corded Phone
Turn answer phone off on Samsung tocco lite mobile
Goto Settings-->Call Settings-->All Calls-->Answering mode.
and check the required options.
Sep 30, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My mobile goes direct to answer machine without ringing
your service provider will provide you with a code to alter the settings for the answer phone , you can adjust how long before the answer phone kicks in and whether the answer phone is on or off
Jul 19, 2009 | Cell Phones
My phone has a answering machine with it but i now have call answer with cable how do i set up the phone to show that i have messages
If you want to use a different answer machine just run the phone line from the wall to the machine you want to use. Be sure you plug in the cord that say's "Line". Then use another cord that will plug into the answer machine that say's "phone". Plug that other end into your phone and be sure to turn the answer machine off on the phone. Good luck.
Apr 15, 2009 | Uniden Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
