Question about Vacuums
How do I replace the drive belt not a Neato robotic vacuum?
I removed all of the screws but can not remove the housing cover.
reddevil6
  • 1673 Answers
SOURCE: vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Posted on Jan 14, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 drive belt replacement
Hi.
The other end of the drive belt the part you cant see goes to a clutch.
The clutch unit has 2 belts one is clutch to motor the second is clutch to brush roller.
You obviously look after your machine because you say you have had no problems with belts or clutch for 5 years.
Both belts & clutch can be worked on but its alot to explain so look at this site for service manuals.
http://dysonmanuals.llc.nu/
Posted on Jun 01, 2008
  • 118 Answers
SOURCE: Removing kenmore vacuum Canister motor cover model 116-27312790
What you need to do is take it apart and look for any carpet peices dug up in there preventing the motor to spin. Also go look for another filter for it and if you google it you can probably get instructions or if you still have the book.
Posted on Jan 31, 2009
SOURCE: How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Posted on Feb 02, 2009
SOURCE: Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Posted on Mar 27, 2009
My neato signature xv says the brush is stuck. I have removed the ends and and there is nothing in the brush. The brush moves freely in the housing. It has been repaired twice for the same problem
Have you checked the belt to see if there is any damage, or if it has come loose? There is diagnostic software created by a Neato user that is available for download at robotreviews [dot] com - in the Neato forum. With this software (which runs on a PC while connected to the Neato via USB cable) you may be able to find the root cause.
Mar 01, 2017 | Neato Vacuums
My Neato XV-12 runs for only a few seconds and stop. The message says, please dust me off I cant see. I have dust and cleaned my neato and it still says the same thing. How do I fix this problem?
Hi Guys
I've fully dismantled my Neato XV-21 to locate the source of the "can't see" problem. (And also replaced a tight wheel Motor causing a "something is caught in my right wheel" message)
There several screws underneath the Neato XV-21 that must be undone to allow the top to be separated. A bit of a pain just to get into the visual sensor area. But not too hard with an electric screwdriver.
There is a Laser device & a Photo sensor mounted to a black plastic rotating wheel which is covered by a black cap with 2 holes in it. One hole for laser beam to exit & one to pick up return laser light return data. They are both rotated by a motor & pulley via a rubber "o" ring which could slip, break or get hairs caught in it.
These could be the source of problems. Once mine was cleaned & checked I had no more problems. Then the wheel motor got tight. Replacing the motor fixed the problem. This requires hoping the Motor Gear Box assembly out by poping the pivot shaft out of it's plastic holder. Then disconnect the spring & cable connector. But you bust be prepared to carefully remove the magnet off the motor shaft (vice & 2 flat blade screw drivers) then unsolder the small PCB at 2 points. With practice (twice) I can now replace a motor in 20-30 minutes.
Hope this Helps some Neato Users out there
Cheers
Trevor
neato-xv-12-runs-only-few-seconds-stop-qnpe3nojpvl4vx0tieerofmg-2-0.png Wheel Motors Here
Wheel and brush motor for Neato XV 11 XV 12 XV 14 XV 15 XV 21 XV Signature...
Apr 05, 2015 | Neato Robotics XV-12 Vacuum System - White
How do I change the belt
start by studying the bottom of the unit . the cover needs to be removed to get to the belt .whatever you remove must be replaced in the reverse when putting back together .I like taking pictures as I go on something I have never done before .
Jan 05, 2015 | Neato Vacuums
Neato robot turns on, fires up vacuum/brushes, but won't move - no error messages. What gives?
I have a Neahis to Botvac 85, had also problem, it started up then stopped. It is 2 or 3 years old, don't remember. but it started to ack very strange with the battery. then this start/stop problem came. I ordered a new originial battery and thought it should solve the problem but no it didn't After some time I decided to try again. Started Neato and it stopped after some time, then I wanted to see if the lidar was rotating so I removed the blue cover over the lidar and could see that it was rotating, then I touched it little bit and the neato started and started to clean my floor. so try this.
Sep 12, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
Neato vacuum display will not come on.
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jul 04, 2014 | Neato XV11 Vacuum
Where can i buy replacement side brushes on line for x500 robot vacuum
Try a site called www.ereplacementparts.com. They carry parts for stuff I never heard of.
Nov 12, 2013 | Neato Robotics Neato XV-21 Pet & Allergy...
Neato vacumm won't turn on
Apr 17, 2013 | Neato Vacuums
Neato XV11 beater bar jam
Are you cleaning the beater bar (including removal and cleaning of the bearings at both sides of the brush) after every run? It's important that you try to minimize the hair that is getting into the drive shaft due to lack of maintenance.
This is a known issue with the XV series. It was improved with Botvac series, and improved even more with Botvac D-Series. The new Connected models hardly get any complaints of this nature, as the design has improved even more.
May 14, 2017 | Neato XV11 Vacuum
How can I reach the brush motor ?
It is not the motor, You have to remove the top cover.To clean it out if the belt is going to slow Some thing is jam in there. There are screws that are probaby on the bottom or top of the unit to hold it together that have to be removed to get it apart.
Oct 26, 2012 | Neato XV11 Vacuum
How to replace belt
Remove the screws on the bottom,
to remove the belt cover
or motor housing cover ,easy to do
2 belts in there
Remove beater bar & take ends off to
clean out hair etc
Jun 18, 2011 | Hoover U8188-900 Bagless Upright Vacuum
Vacuums Logo
97 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
