Pj502 projector lamp and temp light blinking red and the amid go off
  • 3422 Answers
SOURCE: Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Posted on Feb 25, 2008
SOURCE: Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
Posted on Jun 12, 2008
SOURCE: cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Posted on Apr 27, 2009
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
  • 144 Answers
SOURCE: My PJ551 M. Projector is blinking red for LAMP and
This always happens on hitachi projectors aswell,It is just meaning that you need to clean the air vent and reset the timer and then it should be alright.
Posted on May 07, 2010
Testimonial: "Thanks so much. The Filter was cleaned and still, the red was still blinking, so we have reset it and the danger lights are off. "
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Flashing red temp and lamp lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 22, 2014 | Dukane 8912 Projector Lamp 200-Watt...
Red light blinking for lamp and temp
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 20, 2013 | Epson MOVIEMATE 60 PROJECTOR Projector...
Mitsubishi HC2 projector
Was the prvious lamp still working?
Jul 16, 2012 | Mitsubishi HC2 Multimedia Projector
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Blinking lights
it means abnormal operation contact with service center asking help.
Feb 25, 2008 | Mitsubishi LVP-X70U Multimedia Projector
k24674
