Question about Hoover Vacuums
Hoover all terrain steam cleaners hand attachment won't spray. Does gave suction just won't spray.
  • 3 Answers
SOURCE: No suction
I had a a low suction problem. Mine was easily fixed. Stand in front of the machine. When you remove the recovery tank there are the notches on the front of the tank that fit down into the machine. In the right hole in which the right notch fits, there should be a black rubber washer on the machine. Mine somehow came off and feel into the machine therefore there was practically no suction as the seal was not airtight. I only discovered this when I took apart the machine and found it floating around. Just something to check.
Posted on Aug 04, 2007
SOURCE: hoover steam cleaner cleans but no longer suctions up the mess
fart I give up
Posted on Oct 18, 2008
SOURCE: hoover steam vac jr. F5411
First take the guard off the nozzle and remove the nozzle being careful to not let the spring fly. Now pull off the little white tip of the nozzle which less than 1 inch long. Run a needle or fine wire through the main hole running parallel to the hose and make sure you can see it at the head of the nozzel end. It is best to also blow on it to make sure any dirt particles are gone. Even a speck of dust in your solution part of the tank can easily clog it. In 90% of these vacs, that solves the problem and I have repaired at least 50 of them in the past 4 years.
If that doesn't solve it then try this:
Take the impeller on the bottom out by flipping the tank part over, and clean it. Make sure it spins well.
These Hovver Jr Steam Vacs are long lasting and very effective in cleaning spills and stains. Our janitorial company has many of them and in 5 years only one of about 60 has finally been shelved for parts only. I have replaced a few nozzles and several tank latches plus filters, hoses, and the brush and capp on the end of the hose. An additional chore that is made easy with this is defrosting a freezer!
Posted on Dec 04, 2008
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
SOURCE: hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Posted on Mar 09, 2009
Lost manual. How do i hook up the suction part of the furniture upholstery attachment? I know where to plug it in to spray cleaner on the furniture but where does it plug in to **** it up? Model...
on the attachment where you put the attachment remove the lid, then remove the back panal, and slide the suction thing down not much pressure, re apply the lid then put back in vacuum, turn on and there you go...
Sep 02, 2011 | Hoover F5906-900 Upright Steam Vacuum
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
How do i attach the upolstery attachment?
Go to www.Hoover.com Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
Jan 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Jan 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model F5853-900 series 17.9
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Model F5887-920 - hand attachment won't spray
I have a model I got in 2001. I found that the water sprayer on the hand tool is driven by a little turbine that relies on suction from the main vacuum motor. I eventually found that the spindle inside the turbine had separated and hence the hand-tool wouldn't spray. I glued it together but that only fixed the problem until it broke again. I am going to buy another (about $23).
Jul 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Replacement part
http://geeksquad.fixya.com/ThreadView.aspx?prdid=430575&thid=830386
Replacement part
Posted by blassx3 on Jul 25, 2008
I broke a piece of plastic off my furniture attachment and now it will not spray cleaner or suction. Can I get a replacement and will it suction again?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Yes, the best 2 places to get the part or to order the part is your local vacuum cleaner dealer in your area or to contact the Hover website or cust serv line @ the Hoover factory that I will list below, if they do not have the part in stock they can order it for you – make sure you hive them the brand name and model # and sometimes they ask for the serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 25, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover terrain steam cleaner, brushes wont spin
The primary problem is that the turbine is seized. One way to verify this is to try to manually move the brushes by hand (with it off, unplugged). If not then your problem is with the turbine. This usually requires professional service. I would recommend to take it to a trusted vac shop which is familiar with these cleaners. or go to the hoover web site to locate a hoover dealer near you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jul 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
42 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
