Question about Freezers
A chest freezer drain plug for model # WHS-185C1WSB
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
  • 288 Answers
SOURCE: Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Posted on Nov 15, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have an old sears deep chest freezer. I
Clogged drain line. Try using warm water with about six drops of bleach.
Posted on May 29, 2010
heatman101
  • 43501 Answers
SOURCE: where is the drain plug
Most freezer do not have a drain plug...it is very possible that you do not have one on yours...
The best way to get the water out is to siphon with a small hose till there is not much left .... then wipe out the rest with a rag....
Tipping the freezer to one corner will help you siphon more of the water out...
heatman101
Posted on Oct 30, 2010
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Where is the drain plug on a chest freezer
    heatman101
    Oct 30, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
    How do i drain the freezer?
    Some freezers have a plastic drain plug on the side that can be removed, but most do not. I have found the easiest way is to **** up any water in the cavity with a shop vac or bath towels.
    FYI: An authorized servicer is required to drain the refrigerant from the system and requires specialty tools.
    Aug 29, 2010 | Magic Chef Chest Freezer MCCF5WBX
    I bought a used model MFC05M3BW5 chest freezer. I
    Please see attached link for more info, but it appears as though your model has both an internal and external drain plug. Hope this helps
    http://www.youserguide.com/wiki/Electrolux_216657700en-007
    Sep 30, 2009 | Freezers
    Its freezing roun the top and not the bottom?
    is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
    Jul 13, 2009 | General Electric Chest Freezer FCM5SU
    General electric 5.0 chest freezer has water coming all over the floor.
    The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
    May 11, 2009 | General Electric Chest Freezer FCM5SU
    Frigidaire Deluxe Chest Freezer is constantly
    Two things to check without knowing the model number.
    It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
    Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
    May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
    Freezers Logo
    104 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    AJMAL KHAN
    John Tripp
    John Tripp
    Are you a Freezer Expert? Answer questions, earn points and help others
