Question about Garden
Chamberlain 3380 tractor - clutch not engaging. Any suggestions please? Peter M
  • Heather Millard
    Heather Millard Dec 05, 2016
    This is helpful. Thank you
    Habit-Forming:
  • 110 Answers
Motor off - reach where the belts are under the seat and tap or smack those pullys. The one that moves to get you going is stuck. That part may need cleaning and lube. http://www.auto-tune-up-and-repair-options.com/Mega-Power-120-lube-spray.html
Posted on Dec 05, 2016
  • Heather Millard
    Appreciate fact answer offered - it would appear that there is a misunderstanding that the chamberlain 3380 is an (old) agricultural tractor & not a mower type tractor. Thanks anyway. Peter M
  • George Christ Dec 05, 2016
    Ok, lets try this. Follow the clutch linkage to its location going into the bell housing - the big section between engine and transmission. Have someone push clutch down while you notice what the linkage is doing. It should move an arm coming out of the bell housing 1 to 2 inches. Holding those parts should show they're connected. Any sloppy looseness indicates something is not rigth. Maybe a flashlite will reveal it. This section is removes to work on the clutch and internal parts that operate it. The actual clutch is a dish size plate. When it fails trash can be seen and a plate may expose checking it for good or bad. Hope this works. This is a good link for gear additives that help them last longer, move easily, end hard shift.http://www.auto-tune-up-and-repair-optio...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Case tractor problems
The clutch plate is worn out and needs replaced. They are a pain to change so replace the throw out bearing at the same time because they are inexpensive and it is cheap insurance of not having to do the job again.
Jan 31, 2014 | Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Oct 19, 2009 | Craftsman Garden
Early Ford Farm Tracker- Clutch not engaging
Is it a 8N ford tractor or close to that?
Does the transmission grind or hard to put in gear if the clutch is left engaged while placing in a gear.......does it feel like the clutch is driving the transmission?
If so....there is a short drive shaft behind the transmission in the tractor which may have broken.
There's not much else that breaks in there.
Aug 16, 2009 | Ford 8N Tractor
Blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
May 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
